How to manage SSH keys
See also: SSH key
Contents:
Add an SSH key
To add a public ssh key to a model, use the add-ssh-key command followed by a string containing the entire key or an equivalent shell formula:
# Use the entire ssh key:
juju add-ssh-key "ssh-rsa qYfS5LieM79HIOr535ret6xy
AAAAB3NzaC1yc2EAAAADAQA6fgBAAABAQCygc6Rc9XgHdhQqTJ
Wsoj+I3xGrOtk21xYtKijnhkGqItAHmrE5+VH6PY1rVIUXhpTg
pSkJsHLmhE29OhIpt6yr8vQSOChqYfS5LieM79HIOJEgJEzIqC
52rCYXLvr/BVkd6yr4IoM1vpb/n6u9o8v1a0VUGfc/J6tQAcPR
ExzjZUVsfjj8HdLtcFq4JLYC41miiJtHw4b3qYu7qm3vh4eCiK
1LqLncXnBCJfjj0pADXaL5OQ9dmD3aCbi8KFyOEs3UumPosgmh
VCAfjjHObWHwNQ/ZU2KrX1/lv/+lBChx2tJliqQpyYMiA3nrtS
jfqQgZfjVF5vz8LESQbGc6+vLcXZ9KQpuYDt joe@ubuntu"
# Use an equivalent shell formula:
juju add-ssh-key "$(cat ~/mykey.pub)"
See more: juju add-ssh-key
To add a public ssh key to a model, in your Terraform plan create a resource of the juju_ssh_key type, specifying the name of the model and the payload (here, the SSH key itself). For example:
resource "juju_ssh_key" "mykey" {
  model   = juju_model.development.name
  payload = "ssh-rsa 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 user@somewhere"
See more: juju_ssh_key (resource)
To add a public ssh key to a model, on a connected Model object, use the add_ssh_key() method, passing a name for the key and the actual key payload. For example:
SSH_KEY = "ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABgQC1I8QDP79MaHEIAlfh933zqcE8LyUt9doytF3YySBUDWippk8MAaKAJJtNb+Qsi+Kx/RsSY02VxMy9xRTp9d/Vr+U5BctKqhqf3ZkJdTIcy+z4hYpFS8A4bECJFHOnKIekIHD9glHkqzS5Vm6E4g/KMNkKylHKlDXOafhNZAiJ1ynxaZIuedrceFJNC47HnocQEtusPKpR09HGXXYhKMEubgF5tsTO4ks6pplMPvbdjxYcVOg4Wv0N/LJ4ffAucG9edMcKOTnKqZycqqZPE6KsTpSZMJi2Kl3mBrJE7JbR1YMlNwG6NlUIdIqVoTLZgLsTEkHqWi6OExykbVTqFuoWJJY3BmRAcP9H3FdLYbqcajfWshwvPM2AmYb8V3zBvzEKL1rpvG26fd3kGhk3Vu07qAUhHLMi3P0McEky4cLiEWgI7UyHFLI2yMRZgz23UUtxhRSkvCJagRlVG/s4yoylzBQJir8G3qmb36WjBXxpqAGHfLxw05EQI1JGV3ReYOs= user@somewhere"
await my_model.add_ssh_key('admin', SSH_KEY)
See more: add_ssh_key(), Model (module)
Import an SSH key
To import a public SSH key from Launchpad / Github to a model, use the import-ssh-key command followed by lp: / gh: and the name of the user account. For example, the code below imports all the public keys associated with the Github user account ‘phamilton’:
juju import-ssh-key gh:phamilton
See more: juju import-ssh-key
The terraform juju client does not support this. Please use the juju client.
The python-libjuju client does not currently support this. Please use the juju client.
View the available SSH keys
To list the currently known SSH keys for the current model, use the ssh-keys command.
# List the keys known in the current model
juju ssh-keys
If you want to get more details, or get this information for a different model, use the --full or the --model / -m <model name> option.
See more: juju ssh-keys
To list the currently known SSH keys for the current model, on a connected Model object, use the get_ssh_keys() method. For example:
await my_model.get_ssh_keys()
See more: get_ssh_keys(), Model (module)
Remove an SSH key
To remove an SSH key, use the remove-ssh-key command followed by the key / a space-separated list of keys. The keys may be specified by either their fingerprint or the text label associated with them. The example below illustrates both:
juju remove-ssh-key 45:7f:33:2c:10:4e:6c:14:e3:a1:a4:c8:b2:e1:34:b4 bob@ubuntu
See more: juju remove-ssh-key
To remove an SSH key, remove its resource definition from your Terraform plan.
To remove an SSH key, on a connected Model object, use the remove_ssh_key() method, passing the user name and the key as parameters. For example:
await my_model.remove_ssh_key('admin', SSH_KEY)
See more: remove_ssh_key(), Model (module)
Contributors: @cderici, @hmlanigan, @tmihoc
