How to integrate your Charmed Operator with Identity and Access Proxy
Integrate your Charmed Operator with Identity and Access Proxy
Applications that do not conform to OAuth/OIDC standards or don’t offer built-in access control can be secured using the Identity and Access Proxy (IAP) solution, which offers a possibility to protect application endpoints by intercepting incoming requests and delegating the authn/authz process to the relevant components of the Identity Platform.
OAuth2 Proxy is the main entrypoint to plug the Identity and Access Proxy to your charmed operator. It can be achieved using the power of juju relations.
This guide will explain how to extend the Identity Platform with the Identity and Access Proxy solution and integrate it with your charm, allowing you to restrict access to your application to authenticated users only.
We are going to assume that:
  1. Your charmed application doesn’t support the OAuth 2.0/OIDC protocols, otherwise refer to this guide instead.
  2. Your charmed application supports integration with Charmed Traefik via ingress-per-app or ingress-per-unit interface and provides Charmed OAuth2 Proxy with necessary data by supporting the auth_proxy interface.
  3. You have deployed the Identity Platform.
  4. You have deployed your charmed application on Kubernetes.
This deployment should be your starting point:
Model  Controller     Cloud/Region        Version  SLA          Timestamp
iam    my-controller  microk8s/localhost  3.6.13   unsupported  16:37:26+01:00
SAAS           Status  Store  URL
ingress        active  local  admin/core.ingress
postgresql     active  local  admin/core.postgresql
traefik-route  active  local  admin/core.traefik-route
App       Version  Status  Scale  Charm                                Channel        Rev  Address         Exposed  Message
hydra     v2.3.0   active      1  hydra                                latest/stable  395  10.152.183.127  no
kratos    v1.3.1   active      1  kratos                               latest/stable  565  10.152.183.75   no
login-ui  0.24.2   active      1  identity-platform-login-ui-operator  latest/stable  197  10.152.183.135  no
Unit         Workload  Agent  Address      Ports  Message
hydra/0*     active    idle   10.1.57.184
kratos/0*    active    idle   10.1.57.183
login-ui/0*  active    idle   10.1.57.185
Offer              Application  Charm   Rev  Connected  Endpoint     Interface    Role
kratos-info-offer  kratos       kratos  565  0/0        kratos-info  kratos_info  provider
oauth-offer        hydra        hydra   395  0/0        oauth        oauth        provider
In this guide we are going to assume you also deployed your charmed application in iam model.
In order to set up the proxy, you first need to expose forward-auth offer, enable the feature in Charmed Traefik and integrate it with your charm via ingress relation:
juju config traefik-public enable_experimental_forward_auth=True -m core
juju offer traefik-public:experimental-forward-auth forward-auth -m core
juju integrate your-charm admin/core.ingress -m iam
The next step is to deploy Charmed OAuth2 Proxy and integrate it with Charmed Traefik with the exposed offer:
juju deploy oauth2-proxy-k8s --channel latest/stable --trust -m iam
juju integrate oauth2-proxy:forward-auth admin/core.forward-auth -m iam
You can follow the deployment status with watch -c juju status --color.
Then, integrate your charm with the proxy by running:
juju integrate oauth2-proxy-k8s your-charm:auth-proxy -m iam
Finally, integrate the proxy with Identity Platform’s OIDC provider - Charmed Hydra:
juju integrate oauth2-proxy-k8s:oauth hydra -m iam
When you access your application, Charmed Traefik will ask OAuth2 Proxy whether access to the endpoint is protected. If so, it will check if there is a valid session. In case it doesn’t find one, it will redirect to the Identity Platform login page. Upon successful authentication, you will be redirected back to your application.
See more: Charmhub | OAuth2 Proxy > Integrations
