The Identity Platform provides seamless integration with your OIDC compatible charms using the power of juju relations. We are going to assume that:
- You have deployed the identity platform bundle.
- You have deployed an OIDC compatible charmed application.
To connect an OIDC compatible charmed application with the identity-platform bundle, integrate it with hydra:
juju integrate hydra <OIDC compatible charmed application>
Use juju status to inspect the progress of the integration. After the applications have settled down, you should be able to log in to your application using the Identity Platform.
See more: Charmhub | Hydra > Integrations >
oauth
