How to integrate existing PostgreSQL with Openstack Charms?
Is it possible to connect Openstack Charms to an existing PostgreSQL cluster? and how?
There are PostgreSQL charms that I can deploy for Openstack, but I don’t want that, because I already have a PostgreSQL HA cluster.
Hi @rafaahaji,
Charm support for PostgreSQL was deprecated as of the 17.08 release of the OpenStack charms. We’d suggest sticking w/ the MySQL charms deployed as part of the OpenStack bundles as your db back end.
~ PeteVG
Hi @rafaahaji,
Pete is correct. The only supported and tested database integrations with OpenStack Charms are:
  • Before 20.04 (Focal): percona-cluster (a mysql variant).
  • 20.04 (Focal) and later: mysql-innodb-cluster (mysql8).
I hope that helps to clarify.
Cheers,
Ryan
Ok @pengale and @beisner , thanks for your help.
I will try to use mysql-innodb-cluster
