Hi, I’m trying to download/pull a charm from the charmhub and I’m getting a bit confused.
Is charm-tools and charm pull still the only way to do this?
I was trying to download rev 19 of the ubuntu charm which is available in all the channels, however working with charm was not straight forward. It defaulted to referring to the charm store (cs:) and downloaded rev 18 unless ubuntu-19 was specified.
Am I doing something wrong?
P.S. charm still refers to the charm store.
$ charm version
charmstore-client 2.5.1
charm-tools 2.8.2
$ charm pull --help
Usage: charm pull [flags] <charm or bundle id> [--channel <channel>] [<directory>]
Summary:
download a charm or bundle from the charm store
Flags:
do not use web browser for authentication
-a, --agent (= "")
name of file containing agent login details
--auth (= )
user:passwd to use for basic HTTP authentication
-c, --channel (= )
the channel the charm or bundle is assigned to (stable|candidate|beta|edge|unpublished)
Details:
The pull command downloads a copy of a charm or bundle
from the charm store into a local directory.
If the directory is unspecified, the directory
will be named after the charm or bundle, so:
charm pull trusty/wordpress
will fetch the wordpress charm into the
directory "wordpress" in the current directory.
To select a channel, use the --channel option, for instance:
charm pull wordpress --channel edge
$ charm pull ubuntu
cs:ubuntu-18
$ charm pull ch:ubuntu
cs:ubuntu-18
$ charm pull ch:ubuntu --channel latest/stable
ERROR cannot get archive: Invalid channel: latest/stable
$ charm pull ch:ubuntu --channel stable
cs:ubuntu-18
$ charm pull ch:ubuntu-19
cs:ubuntu-19
