Pyroscope HA consists of two charms:
pyroscope-coordinator-k8s, responsible for the ingress and cluster coordinationpyroscope-worker-k8s, which runs the actual workloads.
See more about this architecture:
Requirements: Pyroscope requires an object storage backend (such as Ceph). Typically, that will be through the s3-integrator charm.
Using Terraform
There is a Terraform module that can be used to deploy Pyroscope HA in the pyroscope charm repository.
Before applying the Terraform plan, you need to have your object storage ready together with an endpoint it can be reached over. The following example uses the minio charm, deployed in the same model. Its application IP (http://10.152.183.18:9000) is used as the S3 endpoint URL.
Deployment
In your Terraform repository, create a pyroscope module:
module "pyroscope" {
source = "git::https://github.com/canonical/pyroscope-operators//terraform"
model = var.model
channel = var.channel
s3_endpoint = var.s3_endpoint
s3_access_key = var.s3_access_key
s3_secret_key = var.s3_secret_key
Add relevant input variables to your variables.tf, then run terraform apply.
Note: Currently the
2/edgechannel should be used to deploy Charmed Pyroscope. We’ll be releasing thestabletrack in future once the full profiling flow including Pyroscope and OpenTelemetry Collector stabilizes. See the profiles mappings specification for details of profiles support in OpenTelemetry.
Eventually the model should settle and you’ll get a juju status output similar to the following:
$ juju status
test-big-terra microk8s microk8s/localhost 3.6.7 unsupported 11:03:47+02:00
minio res:oci-image@7f2474f active 1 minio ckf-1.10/edge 459 10.152.183.18 no
pyroscope active 1 pyroscope-coordinator-k8s 2/edge 19 10.152.183.198 no Degraded.
pyroscope-ad-hoc-profiles ... active 1 pyroscope-worker-k8s 2/edge 12 10.152.183.174 no ad-hoc-profiles ready.
pyroscope-compactor ... active 1 pyroscope-worker-k8s 2/edge 12 10.152.183.163 no compactor ready.
pyroscope-distributor ... active 1 pyroscope-worker-k8s 2/edge 12 10.152.183.64 no distributor ready.
pyroscope-ingester ... active 1 pyroscope-worker-k8s 2/edge 12 10.152.183.123 no ingester ready.
pyroscope-querier ... active 1 pyroscope-worker-k8s 2/edge 12 10.152.183.157 no querier ready.
pyroscope-query-frontend ... active 1 pyroscope-worker-k8s 2/edge 12 10.152.183.190 no query-frontend ready.
pyroscope-query-scheduler ... active 1 pyroscope-worker-k8s 2/edge 12 10.152.183.154 no query-scheduler ready.
pyroscope-s3-integrator active 1 s3-integrator 2/edge 157 10.152.183.184 no
pyroscope-store-gateway ... active 1 pyroscope-worker-k8s 2/edge 12 10.152.183.173 no store-gateway ready.
pyroscope-tenant-settings ... active 1 pyroscope-worker-k8s 2/edge 12 10.152.183.52 no tenant-settings ready.
minio/0* active idle 10.1.157.108 9000-9001/TCP
pyroscope-ad-hoc-profiles/0* active idle 10.1.157.127 ad-hoc-profiles ready.
pyroscope-compactor/0* active idle 10.1.157.72 compactor ready.
pyroscope-distributor/0* active idle 10.1.157.96 distributor ready.
pyroscope-ingester/0* active idle 10.1.157.81 ingester ready.
pyroscope-querier/0* active idle 10.1.157.77 querier ready.
pyroscope-query-frontend/0* active idle 10.1.157.80 query-frontend ready.
pyroscope-query-scheduler/0* active idle 10.1.157.105 query-scheduler ready.
pyroscope-s3-integrator/0* active idle 10.1.157.102
pyroscope-store-gateway/0* active idle 10.1.157.101 store-gateway ready.
pyroscope-tenant-settings/0* active idle 10.1.157.79 tenant-settings ready.
pyroscope/0* active idle 10.1.157.106 Degraded.
Customizing the deployment
By default, the deployment will create one worker unit for every required role. You can fine-tune that to your needs using terraform input variables. See Inputs for the full list of available configurations.
Monolithic deployment mode for testing and dev
If you want just to experiment with pyroscope, you can also manually deploy it in monolithic mode, which means having a single worker with the all role (which is the default), instead of the one-worker-application-per-role distributed mode. You will still need an object storage backend and s3-integrator pointing at the s3 endpoint.
juju deploy pyroscope-coordinator-k8s pyroscope --channel=2/edge --trust
juju deploy pyroscope-worker-k8s pyroscope-worker --channel=2/edge --trust
juju relate pyroscope pyroscope-worker
juju relate pyroscope s3-integrator
