Sometimes developers need to store some new entities in Juju DB. This document provides key points for adding a new collection to MongoDB.
Contents:
- Define a new collection in Juju DB
- Define a new entity collection structure
- Develop an API to manipulate collection entities
All collections are represented in the package state. This package enables reading, observing, and changing the state stored in MongoDB of a whole model managed by juju.
A developer can define a new collection in: https://github.com/juju/juju/blob/develop/state/allcollections.go
Example of a new collection definition:
newEntitiesC: {
indexes: []mgo.Index{{
Key: []string{"model-uuid", "unit-id"},
newEntitiesC = "newEntities"
Create a golang file in the state subfolder: state/new_entites.go
Add state shim to interact with the Juju global state in your API:
// NewEntitiesState returns the new entities for the current state.
func (st *State) NewEntityState() *new EntityPersistence {
return &newEntityPersistence{
st: st,
// serviceLocatorPersistence provides the persistence
// functionality for service locators.
type serviceLocatorPersistence struct {
st *State
Define a logger to be able to write logs from your API:
var neLogger = logger.Child("new-entity")
Define a New Entity structure:
type NewEntity struct {
st *State
doc newEntityDoc
Define the document structure for the new MongoDB collection:
type newEntityDoc struct {
DocId string `bson:"_id"`
Id int `bson:"id"`
UnitId string `bson:"unit-id"`
Param1 string `bson:"param-1"`
Param2 string `bson:"param-2"`
OtherParams map[string]interface{} `bson:"other-params"`
You then need to implement methods that will help you interact with new collection docs. Let’s define some simple CRUD methods for ‘new entity’.
Add a new doc
Here is an example of a way to add a new doc to a MongoDB collocation:
// AddNewEntity creates a new entity record, which ...
func (ne *newEntityPersistence) AddNewEntity(args params.AddNewEntityParams) (*NewEntity, error) {
id, err := sequenceWithMin(sp.st, "new-entity", 1)
if err != nil {
return nil, errors.Trace(err)
defer errors.DeferredAnnotatef(&err, "cannot add new entity %q", args.Name)
model, err := ne.st.Model()
if err != nil {
} else if model.Life() != Alive {
return nil, errors.Errorf("model is no longer alive")
newEntityDoc := newEntityDoc{
DocId: fmt.Sprintf("%s.%s", args.Name, args.UnitId),
Param1: args.Param1,
Param2: args.Param2,
UnitId: args.UnitId,
Params: args.Params,
buildTxn := func(attempt int) ([]txn.Op, error) {
// If we've tried once already and failed, check that
// model may have been destroyed.
if attempt > 0 {
if err := checkModelActive(sp.st); err != nil {
return nil, errors.AlreadyExistsf("new entity name: %s unit-id: %s", args.Name, args.UnitId)
ops := []txn.Op{
model.assertActiveOp(),
C: newEntitiesC,
Assert: txn.DocMissing,
Insert: &newEntityDoc,
return ops, nil
if err = sp.st.db().Run(buildTxn); err != nil {
return &NewEntity{doc: newEntityDoc}, nil
Remove a new doc
Here is an example of a way to remove a new doc from a MongoDB collocation:
// RemoveNewEntities removes a service locator record
func (ne *newEntitiesPersistence) RemoveNewEntity(neId string) []txn.Op {
op := txn.Op{
C: newEntitiesC,
Remove: true,
return []txn.Op{op}
