How to correctly setup ovn-dedicated-chassis ?
Hi,
After sucessfully configured neutron-api , nova-compute, ovn-central and ovn-chassis and tested all , and everything is working I add one new ovn-dedicated-chassis with following commands .
# juju deploy --channel 23.09/stable --config neutron.yaml ovn-dedicated-chassis --to=us-ovn-chassi-vm-01
# juju integrate ovn-dedicated-chassis:ovsdb ovn-central:ovsdb
# juju integrate ovn-dedicated-chassis:certificates vault:certificates
where the content of neutron.yaml is :
ovn-chassis:
  bridge-interface-mappings: 'ovsbr2004:eno3.2004 ovsbr2000:eno2'
  ovn-bridge-mappings: 'physnet1:ovsbr2004 physnet2:ovsbr2000'
neutron-api:
  neutron-security-groups: true
  flat-network-providers: "physnet1 physnet2"
  debug: true
  verbose: true
  bridge-interface-mappings: 'ovsbr-us01:enp2s0'
  ovn-bridge-mappings: 'physnet-us01:ovsbr-us01'
the juju status ovn* output is :
openstack  maas-dc3-default  maas-dc3/default  3.1.8    unsupported  23:32:41Z
App                       Version  Status  Scale  Charm                   Channel        Rev  Exposed  Message
ceph-osd                           active      0  ceph-osd                reef/stable    577  no       Unit is ready (1 OSD)
neutron-api               23.1.0   active      1  neutron-api             2023.2/stable  583  no       Unit is ready
neutron-api-mysql-router  8.0.37   active      0  mysql-router            8.0/stable     189  no       Unit is ready
neutron-api-plugin-ovn    23.1.0   active      0  neutron-api-plugin-ovn  2023.2/stable  113  no       Unit is ready
nova-compute              28.0.1   active      3  nova-compute            2023.2/stable  718  no       Unit is ready
ovn-central               22.09.1  active      2  ovn-central             23.09/stable   190  no       Unit is ready (northd: active)
ovn-chassis               23.09.0  active      3  ovn-chassis             23.09/stable   233  no       Unit is ready
ovn-dedicated-chassis     22.03.3  active      1  ovn-dedicated-chassis   23.09/stable   132  no       Unit is ready
Unit                           Workload  Agent  Machine  Public address  Ports          Message
neutron-api/0*                 active    idle   24       172.19.0.116    9696/tcp       Unit is ready
  neutron-api-mysql-router/0*  active    idle            172.19.0.116                   Unit is ready
  neutron-api-plugin-ovn/0*    active    idle            172.19.0.116                   Unit is ready
nova-compute/7*                active    idle   10       172.19.0.14                    Unit is ready
  ovn-chassis/3*               active    idle            172.19.0.14                    Unit is ready
nova-compute/8                 active    idle   12       172.19.0.13                    Unit is ready
  ovn-chassis/2                active    idle            172.19.0.13                    Unit is ready
nova-compute/9                 active    idle   13       172.19.0.12                    Unit is ready
  ovn-chassis/0                active    idle            172.19.0.12                    Unit is ready
ovn-central/3*                 active    idle   24       172.19.0.116    6641-6642/tcp  Unit is ready (northd: active)
ovn-central/4                  active    idle   25       172.19.0.117    6641-6642/tcp  Unit is ready (leader: ovnnb_db, ovnsb_db)
ovn-dedicated-chassis/5*       active    idle   47       172.16.92.14                   Unit is ready
Machine  State    Address       Inst id              Base          AZ                Message
10       started  172.19.0.14   srv-compute-04       ubuntu@22.04  default           Deployed
12       started  172.19.0.13   srv-compute-03       ubuntu@22.04  default           Deployed
13       started  172.19.0.12   srv-compute-02       ubuntu@22.04  default           Deployed
24       started  172.19.0.116  neutron-vm-01        ubuntu@22.04  default           Deployed
25       started  172.19.0.117  neutron-vm-02        ubuntu@22.04  default           Deployed
47       started  172.16.92.14  us-ovn-chassi-vm-01  ubuntu@22.04  us-psychz-dallas  Deployed
The ovn success create the route on it as describe at juju exec --unit ovn-central/4 ‘ovn-nbctl lr-list’
b7ce849c-4e65-48b1-b63f-08ac93133e78 (neutron-509d5f16-8ff3-4b56-80bb-bf6610050045)
a442144c-0566-4d93-bc43-c715482fa131 (neutron-7ba69395-d7cb-4e04-9a63-2f9121c14a57)
The agent was correctly set
root@juju-vm-01:~# openstack network agent list
| ID                                   | Agent Type           | Host                     | Availability Zone | Alive | State | Binary                     |
| us-ovn-chassi-vm-01.maas             | OVN Controller agent | us-ovn-chassi-vm-01.maas |                   | :-)   | UP    | ovn-controller             |
| srv-compute-04.maas                  | OVN Controller agent | srv-compute-04.maas      |                   | :-)   | UP    | ovn-controller             |
| 393ddc3c-007c-5e12-822b-d0fe92876ae2 | OVN Metadata agent   | srv-compute-04.maas      |                   | :-)   | UP    | neutron-ovn-metadata-agent |
| srv-compute-03.maas                  | OVN Controller agent | srv-compute-03.maas      |                   | :-)   | UP    | ovn-controller             |
| 6a84b4c9-0ffe-5712-a246-394dfb2056a5 | OVN Metadata agent   | srv-compute-03.maas      |                   | :-)   | UP    | neutron-ovn-metadata-agent |
| srv-compute-02.maas                  | OVN Controller agent | srv-compute-02.maas      |                   | :-)   | UP    | ovn-controller             |
| f00652d5-9d85-5a43-ab9c-c07184137e7e | OVN Metadata agent   | srv-compute-02.maas      |                   | :-)   | UP    | neutron-ovn-metadata-agent |
all network openvswitch was correctly setup
root@us-ovn-chassi-vm-01:~# ovs-vsctl show
77336bda-281f-47fc-a7c0-24316c8bbd49
    Bridge ovsbr-us01
        fail_mode: standalone
        datapath_type: system
        Port ovsbr-us01
            Interface ovsbr-us01
                type: internal
        Port enp2s0
            Interface enp2s0
                type: system
        Port patch-provnet-2a99c055-8f5a-4de7-9e8e-cba7a03d1a3f-to-br-int
            Interface patch-provnet-2a99c055-8f5a-4de7-9e8e-cba7a03d1a3f-to-br-int
                type: patch
                options: {peer=patch-br-int-to-provnet-2a99c055-8f5a-4de7-9e8e-cba7a03d1a3f}
    Bridge br-int
        fail_mode: secure
        Port patch-br-int-to-provnet-2a99c055-8f5a-4de7-9e8e-cba7a03d1a3f
            Interface patch-br-int-to-provnet-2a99c055-8f5a-4de7-9e8e-cba7a03d1a3f
                type: patch
                options: {peer=patch-provnet-2a99c055-8f5a-4de7-9e8e-cba7a03d1a3f-to-br-int}
        Port br-int
            Interface br-int
                type: internal
        Port ovn-srv-co-1
            Interface ovn-srv-co-1
                type: geneve
                options: {csum="true", key=flow, remote_ip="172.19.8.14"}
        Port ovn-srv-co-0
            Interface ovn-srv-co-0
                type: geneve
                options: {csum="true", key=flow, remote_ip="172.19.8.13"}
        Port ovn-srv-co-2
            Interface ovn-srv-co-2
                type: geneve
                options: {csum="true", key=flow, remote_ip="172.19.8.12"}
    ovs_version: "2.17.9"
At all process the unique error that I found is at /var/log/ovn/ovn-controller.log
2024-06-21T22:40:06.446Z|00048|binding|INFO|Claiming lport cr-lrp-d279bca1-935a-47cd-b0bd-dbed8ac43446 for this chassis.
2024-06-21T22:40:06.446Z|00049|binding|INFO|cr-lrp-d279bca1-935a-47cd-b0bd-dbed8ac43446: Claiming fa:16:3e:f0:4b:d0 XXX.XXX.XXX.XXX/28
2024-06-21T22:40:06.447Z|00050|lflow|WARN|error parsing actions "reg0[15] = check_out_port_sec(); next;": Syntax error at `check_out_port_sec' expecting field name.
when I look at unit now neutron package is installed . Should it not have it ? Is that correct ? the fa:16:3e:f0:4b:d0 is the MAC address from the virtual router , what is missing to create it ?
Best regards,
Saulo
