How to connect mlmd charm to kubeflow pipeline?
I have deployed mlmd via juju.
I need to config metdata connection for tfx pipeline:
metadata_config = tfx.orchestration.experimental.get_default_kubeflow_metadata_config()
    # metadata_config.mysql_db_service_host.value = 'mysql.kubeflow'
    # metadata_config.mysql_db_service_port.value = "3306"
    # metadata_config.mysql_db_name.value = "metadb"
    # metadata_config.mysql_db_user.value = "root"
    # metadata_config.mysql_db_password.value = ""
    metadata_config.grpc_config.grpc_service_host.value = 'metadata-grpc-service.kubeflow'
    metadata_config.grpc_config.grpc_service_port.value = '8080'
What host, port, name, user and password should I used for mlmd charm?
Here the list of services:
modeloperator                        ClusterIP      10.152.183.78    <none>         17071/TCP                               16d
admission-webhook-operator           ClusterIP      10.152.183.126   <none>         30666/TCP                               16d
argo-controller-operator             ClusterIP      10.152.183.116   <none>         30666/TCP                               16d
argo-server-operator                 ClusterIP      10.152.183.212   <none>         30666/TCP                               16d
dex-auth-endpoints                   ClusterIP      None             <none>         <none>                                  16d
istio-ingressgateway                 ClusterIP      10.152.183.44    <none>         65535/TCP                               16d
istio-ingressgateway-endpoints       ClusterIP      None             <none>         <none>                                  16d
istio-pilot                          ClusterIP      10.152.183.99    <none>         65535/TCP                               16d
istio-pilot-endpoints                ClusterIP      None             <none>         <none>                                  16d
jupyter-controller-operator          ClusterIP      10.152.183.217   <none>         30666/TCP                               16d
jupyter-ui-operator                  ClusterIP      10.152.183.123   <none>         30666/TCP                               16d
katib-controller-operator            ClusterIP      10.152.183.81    <none>         30666/TCP                               16d
admission-webhook                    ClusterIP      10.152.183.129   <none>         4443/TCP                                16d
katib-db-operator                    ClusterIP      10.152.183.90    <none>         30666/TCP                               16d
katib-db-manager-operator            ClusterIP      10.152.183.3     <none>         30666/TCP                               16d
katib-ui-operator                    ClusterIP      10.152.183.114   <none>         30666/TCP                               16d
kubeflow-roles                       ClusterIP      10.152.183.145   <none>         65535/TCP                               16d
kubeflow-roles-endpoints             ClusterIP      None             <none>         <none>                                  16d
katib-db                             ClusterIP      10.152.183.229   <none>         3306/TCP                                16d
katib-db-endpoints                   ClusterIP      None             <none>         <none>                                  16d
kfp-profile-controller-operator      ClusterIP      10.152.183.242   <none>         30666/TCP                               16d
kfp-api-operator                     ClusterIP      10.152.183.196   <none>         30666/TCP                               16d
metacontroller-operator              ClusterIP      10.152.183.156   <none>         65535/TCP                               16d
metacontroller-operator-endpoints    ClusterIP      None             <none>         <none>                                  16d
kfp-db-operator                      ClusterIP      10.152.183.87    <none>         30666/TCP                               16d
jupyter-ui                           ClusterIP      10.152.183.84    <none>         5000/TCP                                16d
kfp-persistence-operator             ClusterIP      10.152.183.239   <none>         30666/TCP                               16d
katib-controller                     ClusterIP      10.152.183.176   <none>         443/TCP,8080/TCP                        16d
kfp-schedwf-operator                 ClusterIP      10.152.183.133   <none>         30666/TCP                               16d
training-operator                    ClusterIP      10.152.183.56    <none>         65535/TCP                               16d
training-operator-endpoints          ClusterIP      None             <none>         <none>                                  16d
kfp-db                               ClusterIP      10.152.183.23    <none>         3306/TCP                                16d
kfp-db-endpoints                     ClusterIP      None             <none>         <none>                                  16d
katib-db-manager                     ClusterIP      10.152.183.43    <none>         6789/TCP                                16d
katib-ui                             ClusterIP      10.152.183.179   <none>         8080/TCP                                16d
kfp-viewer-operator                  ClusterIP      10.152.183.194   <none>         30666/TCP                               16d
kfp-viz-operator                     ClusterIP      10.152.183.226   <none>         30666/TCP                               16d
kubeflow-dashboard-operator          ClusterIP      10.152.183.157   <none>         30666/TCP                               16d
kfp-ui-operator                      ClusterIP      10.152.183.76    <none>         30666/TCP                               16d
tensorboard-controller-operator      ClusterIP      10.152.183.155   <none>         30666/TCP                               16d
kubeflow-profiles-operator           ClusterIP      10.152.183.80    <none>         30666/TCP                               16d
seldon-controller-manager-operator   ClusterIP      10.152.183.70    <none>         30666/TCP                               16d
oidc-gatekeeper-operator             ClusterIP      10.152.183.65    <none>         30666/TCP                               16d
tensorboards-web-app-operator        ClusterIP      10.152.183.147   <none>         30666/TCP                               16d
kubeflow-volumes-operator            ClusterIP      10.152.183.192   <none>         30666/TCP                               16d
minio-operator                       ClusterIP      10.152.183.168   <none>         30666/TCP                               16d
kfp-viz                              ClusterIP      10.152.183.208   <none>         8888/TCP                                16d
seldon-controller-manager            ClusterIP      10.152.183.143   <none>         8080/TCP,4443/TCP                       16d
kubeflow-profiles                    ClusterIP      10.152.183.101   <none>         8080/TCP,8081/TCP                       16d
kfp-api                              ClusterIP      10.152.183.134   <none>         8888/TCP,8887/TCP                       16d
dex-auth                             ClusterIP      10.152.183.20    <none>         5556/TCP                                16d
istiod                               ClusterIP      10.152.183.161   <none>         15010/TCP,15012/TCP,443/TCP,15014/TCP   16d
seldon-webhook-service               ClusterIP      10.152.183.118   <none>         4443/TCP                                16d
istio-ingressgateway-workload        LoadBalancer   10.152.183.51    10.64.140.43   80:30988/TCP,443:32703/TCP              16d
oidc-gatekeeper                      ClusterIP      10.152.183.127   <none>         8080/TCP                                16d
kfp-ui                               ClusterIP      10.152.183.128   <none>         3000/TCP                                16d
kubeflow-dashboard                   ClusterIP      10.152.183.189   <none>         8082/TCP                                16d
kfp-profile-controller               ClusterIP      10.152.183.158   <none>         80/TCP                                  16d
tensorboard-controller               ClusterIP      10.152.183.73    <none>         9443/TCP                                16d
mlmd-operator                        ClusterIP      10.152.183.71    <none>         30666/TCP                               7d3h
metadata-grpc-service                ClusterIP      10.152.183.58    <none>         8080/TCP                                7d3h
mlmd                                 ClusterIP      10.152.183.77    <none>         8080/TCP                                7d3h
mlmd-endpoints                       ClusterIP      None             <none>         <none>                                  7d3h
