The Apache Kafka benchmark charm uses the OpenMessaging tool to test both producer and consumer performance in the cluster.
The OpenMessaging allows for a distributed deployment, where the charm leader will run the main “manager” process and gather the metrics, whilst other units will act as followers and act as producer/consumers of the cluster.
Deploy
Apache Kafka benchmark charm can be connected with either the Charmed Apacke Kafka or the Charmed Apache Kafka K8s.
Apache Kafka setup
Deploy the apropriate charmed operator for the type of your Juju cloud environment:
- For Machine clouds, see the How to deploy guide for Charmed Apache Kafka.
- For Kubernetes clouds, see the How to deploy guide for Charmed Apache Kafka K8s. Since the benchmark charm is for machine clouds only, the Apache Kafka cluster must be deployed on a different (Kubernetes) environment. Hence, it must be configured to expose its client endpoints via NodePort.
Benchmark deployment
The Apache Kafka benchmark runs several producers and consumers for the same topic with the right number of partitions to enable parallelism. The total number of parallel workers is equal to the number of units for the benchmark application multiplied by the number of workers on each unit. The number of workers per unit is set by the parallel_processes parameter.
The workers are distributed equally between producers and consumers. Hence, the Apache Kafka benchmark needs at least two workers in total. That minimal configuration can be achieved by having two workers on the same single unit or two units with one worker on each.
Deploy the benchmark charm with the desired number of units and workers per unit. For example, to deploy two units with one worker (either a consumer or a producer) on each, run:
juju deploy kafka-benchmark --channel=latest/edge -n2 --config parallel_processes=1
Each unit must have at least 4 GB of RAM available for each running worker.
Once the benchmark charm is deployed and ready, integrate it with the Apache Kafka cluster:
juju integrate kafka kafka-benchmark
Integrate with COS
The benchmark charm needs a COS deployment running on a separate Juju model in Kubernetes to collect metrics during the test. Relate the Apache Kafka benchmark with a grafana-agent operator.
For instructions on how to deploy and configure COS and its agents, see the How to enable monitoring guide.
Once the grafana-agent is deployed, relate it with:
juju relate grafana-agent kafka-benchmark
The benchmark data will be collected every 10s and sent to prometheus.
Integrate with TLS
Optionally, the entire deployment can use TLS.
Charmed Apache Kafka supports TLS provider integration as described for both machine and k8s charmed operators, such as self-signed-certificates, for example:
juju integrate kafka-benchmark self-signed-certificates
Run the benchmark
Now that the benchmark charm is deployed to all intended units, we can adjust benchmarking parameters and control the whole cluster by using the charm’s actions on the leader unit.
You can adjust benchmarking parameters with the juju config command:
juju config kafka-benchmark run_count=3
For all configuration options, see the Configurations.
Prepare
The first step is to prepare the benchmark fleet with:
juju run kafka-benchmark/leader prepare
Start
Use the run action, to start benchmarking (to produce and consume data):
juju run kafka-benchmark/leader run
The units will pick-up the command and start executing the benchmark.
Stop
To stop the benchmark, execute:
juju run kafka-benchmark/leader stop
Optionally, it is possible to clean the current benchmark data using:
Clean-up
To return the cluster to its original state, run:
juju run kafka-benchmark/leader cleanup
Get the results
Kafka benchmark charm updates its metrics to COS and can be found under openmessaging_ metric on prometheus:
