Hi,
Openstack documentation mentions three disks (min 3x80GB) are required for the deployment of Openstack using MAAS and JUJU. This was two before. Are these physical disks or can be logical disks as well? If three physical disks are the minimum, is there any workaround for a situation where only two disks are available on the server, for example, Dell PowerEdge m620?
For Charmed OpenStack, the minimum number of cloud nodes is three (physical machines). Each of these nodes requires two (physical) disks; one for the host and one for a Ceph OSD. I’m basing this on the Charm Guide as documentation resource. I am not aware of any workaround for this.
Hmm yeah, that is not worded well. It says “3 x 80GiB storage”. I’ll fix that today. It should be two disks per node. One for the host’s root disk and one for a Ceph OSD.
Thank you for your reply. I’m familiar with the two-disk requirement and was surprised to see that it was changed in the documentation. Now the Requirement says:
4 x cloud nodes: 8GiB RAM, 2 CPUs, 1 NIC, 2 x 80GiB storage
but at the bottom of the page is still 3 disks and later in ceph-osd conf as I showed above.
Thank you for your tenacity in this matter. There is a difference between requirements and what can actually be done, but I agree that we should stick with the requirements throughout to avoid confusion. Updates will be made soon to the table and the ceph-osd configuration.
