deploy postgresql cluster by juju, but i can’t access the pg server.
I have no clue - perhaps @mthaddon would know?
@mykola.marzhan ping! (I know that your team is in the middle of a lot of work on the charm – can you provide some advice here?)
Hi @lance-xu!
Could you share some info about your environment?
I tried to reproduce the issue, but could not get the connection problem. The connection is working on my environment.
Probably the info about your juju and microk8s installations (including versions, enabled addons, and if it’s running on your local machine or some remote environment) should be helpful for us to figured out what’s the cause of the usse.
