When I run juju list-storage-pools
I get some storage pools which I can’t really trace. How can I force its removal as I suspect it’s affecting my units which are returning the error message failed creating instances: cannot find storage pool
Also the error message also failed to indicate which storage pool is being specified. I’m using LXD local cloud.
doesn’t look like a juju error message;it’s probably coming from lxc
Can you provide more information about your deployment:
- what version of juju
- what version of lxd
- what was the command line used to deploy the application
- what does
lxc storage list
show
The solution was to create storage pool named default
on lxd. The charm bundle I was trying to deploy was charmed-kubernetes
