The information in this doc is based on Juju version 3.5.8, and may not accurately reflect other versions of Juju.
See also: state-delete, state-get
Set server-side-state values.
Usage
state-set [options] key=value [key=value ...]
Options
| Flag | Default | Usage |
--file |
file containing key-value pairs |
Details
state-set sets the value of the server side state specified by key.
The --file option should be used when one or more key-value pairs are too long to fit within the command length limit of the shell or operating system. The file will contain a YAML map containing the settings as strings. Settings in the file will be overridden by any duplicate key-value arguments. A value of “-” for the filename means <stdin>.
The following fixed size limits apply:
- Length of stored keys cannot exceed 256 bytes.
- Length of stored values cannot exceed 65536 bytes.
