The information in this doc is based on Juju version 3.5.8, and may not accurately reflect other versions of Juju.
Add a new secret.
Usage
secret-add [options] [key[#base64|#file]=value...]
Options
| Flag | Default | Usage |
--description |
the secret description | |
--expire |
either a duration or time when the secret should expire | |
--file |
a YAML file containing secret key values | |
--label |
a label used to identify the secret in hooks | |
--owner |
application | the owner of the secret, either the application or unit |
--rotate |
the secret rotation policy |
Details
Add a secret with a list of key values.
If a key has the ‘#base64’ suffix, the value is already in base64 format and no encoding will be performed, otherwise the value will be base64 encoded prior to being stored.
If a key has the ‘#file’ suffix, the value is read from the corresponding file.
By default, a secret is owned by the application, meaning only the unit leader can manage it. Use “–owner unit” to create a secret owned by the specific unit which created it.
Examples:
secret-add token=34ae35facd4
secret-add key#base64=AA==
secret-add key#file=/path/to/file another-key=s3cret
secret-add --owner unit token=s3cret
secret-add --rotate monthly token=s3cret
secret-add --expire 24h token=s3cret
secret-add --expire 2025-01-01T06:06:06 token=s3cret
secret-add --label db-password \
--description "my database password" \
data#base64=s3cret==
--file=/path/to/file
