The information in this doc is based on Juju version 3.5.8, and may not accurately reflect other versions of Juju.
Get the path to the locally cached resource file.
Usage
resource-get [options] <resource name>
Details
“resource-get” is used while a hook is running to get the local path to the file for the identified resource. This file is an fs-local copy, unique to the unit for which the hook is running. It is downloaded from the controller, if necessary.
If “resource-get” for a resource has not been run before (for the unit) then the resource is downloaded from the controller at the revision associated with the unit’s application. That file is stored in the unit’s local cache. If “resource-get” has been run before then each subsequent run syncs the resource with the controller. This ensures that the revision of the unit-local copy of the resource matches the revision of the resource associated with the unit’s application.
Either way, the path provided by “resource-get” references the up-to-date file for the resource. Note that the resource may get updated on the controller for the application at any time, meaning the cached copy may be out of date at any time after you call “resource-get”. Consequently, the command should be run at every point where it is critical that the resource be up to date.
The “upgrade-charm” hook is useful for keeping your charm’s resources on a unit up to date. Run “resource-get” there for each of your charm’s resources to do so. The hook fires whenever the the file for one of the application’s resources changes on the controller (in addition to when the charm itself changes). That means it happens in response to “juju upgrade-charm” as well as to “juju push-resource”.
Note that the “upgrade-charm” hook does not run when the unit is started up. So be sure to run “resource-get” for your resources in the “install” hook (or “config-changed”, etc.).
Note that “resource-get” only provides an FS path to the resource file. It does not provide any information about the resource (e.g. revision).
