The information in this doc is based on Juju version 3.5.8, and may not accurately reflect other versions of Juju.
List all ports or port ranges opened by the unit.
Options
| Flag | Default | Usage |
--endpoints |
false | display the list of target application endpoints for each port range |
--format |
smart | Specify output format (json|smart|yaml) |
-o, --output |
Specify an output file |
Details
opened-ports lists all ports or port ranges opened by a unit.
By default, the port range listing does not include information about the application endpoints that each port range applies to. Each list entry is formatted as <port>/<protocol> (e.g. “80/tcp”) or <from>-<to>/<protocol> (e.g. “8080-8088/udp”).
If the --endpoints option is specified, each entry in the port list will be augmented with a comma-delimited list of endpoints that the port range applies to (e.g. “80/tcp (endpoint1, endpoint2)”). If a port range applies to all endpoints, this will be indicated by the presence of a '’ character (e.g. "80/tcp ()").
