The information in this doc is based on Juju version 3.5.8, and may not accurately reflect other versions of Juju.
Get network config.
Usage
network-get [options] <binding-name> [--ingress-address] [--bind-address] [--egress-subnets]
Options
| Flag | Default | Usage |
--bind-address |
false | get the address for the binding on which the unit should listen |
--egress-subnets |
false | get the egress subnets for the binding |
--format |
smart | Specify output format (json|smart|yaml) |
--ingress-address |
false | get the ingress address for the binding |
-o, --output |
Specify an output file | |
--primary-address |
false | (deprecated) get the primary address for the binding |
-r, --relation |
specify a relation by id |
Details
network-get returns the network config for a given binding name. By default it returns the list of interfaces and associated addresses in the space for the binding, as well as the ingress address for the binding. If defined, any egress subnets are also returned. If one of the following flags are specified, just that value is returned. If more than one flag is specified, a map of values is returned.
--bind-address: the address the local unit should listen on to serve connections, as well
as the address that should be advertised to its peers.
--ingress-address: the address the local unit should advertise as being used for incoming connections.
--egress-subnets: subnets (in CIDR notation) from which traffic on this relation will originate.
