Hook command 'action-set'
The information in this doc is based on Juju version 3.5.8, and may not accurately reflect other versions of Juju.
Set action results.
Usage
action-set [options] <key>=<value> [<key>=<value> ...]
Details
action-set adds the given values to the results map of the Action. This map is returned to the user after the completion of the Action. Keys must start and end with lowercase alphanumeric, and contain only lowercase alphanumeric, hyphens and periods. The following special keys are reserved for internal use: “stdout”, “stdout-encoding”, “stderr”, “stderr-encoding”.
Example usage:
action-set outfile.size=10G
action-set foo.bar=2
action-set foo.baz.val=3
action-set foo.bar.zab=4
action-set foo.baz=1
will yield:
outfile:
foo:
  bar:
    zab: "4"
  baz: "1"
