Charm developers have had many discussion about “holistic” charms compared to “delta” charms, and which approach is better. First, let’s define those terms:
- A delta-based charm is when the charm handles each kind of Juju hook with a separate handler function, which does the minimum necessary to process that kind of event.
- A holistic charm handles some or all Juju hooks using a common code path such as
_update_charm
, which queries the charm config and relation data and “rewrites the world”, that is, rewrites application configuration and restarts necessary services.
Juju itself nudges charm authors in the direction of delta-based charms, because it provides specific event kinds that signal that one “thing” changed: config-changed
says that a config value changed, relation-changed
says that relation data has changed, pebble-ready
signals that the Pebble container is ready, and so on.
However, this only goes so far: config-changed
doesn’t tell the charm which config keys changed, and relation-changed
doesn’t tell the charm how the relation data changed.
In addition, the charm may receive an event like config-changed
before it’s ready to handle it, for example, if the container is not yet ready (pebble-ready
has not yet been triggered). In such cases, charms could try to wait for both events to occur, possibly storing state to track which events have occurred – but that is error-prone.
Alternatively, a charm can use a holistic approach and handle both config-changed
and pebble-ready
with a single code path, as in this example:
class MyCharm(ops.CharmBase):
def __init__(self, framework: ops.Framework):
super().__init__(framework)
framework.observe(self.on.config_changed, self._update_charm)
framework.observe(self.on['redis'].pebble_ready, self._update_charm)
def _update_charm(self, _: ops.EventBase): # event parameter isn't used
redis_port = self.config.get('redis-port')
if not redis_port:
# pebble-ready happened first, wait for config-changed
return
# If both the Pebble container and config are ready, rewrite the
# container's config file and restart Redis if needed.
container = self.unit.get_container('redis')
try:
self._update_redis_config(container, redis_port)
except ops.pebble.ConnectionError:
# config-changed happened first, wait for pebble-ready
return
When to use the holistic approach
If a charm is waiting for a collection of events, as in the example above, it makes sense to group those events together and handle them holistically, with a single code path.
In other words, when writing a charm, it’s not so much “should the charm be holistic?” as “does it make sense for these events to be handled holistically?”
Using the holistic approach is normally centred around configuring an application. Various events that affect configuration use a common handler, to simplify writing an application config file and restarting the application. This is common for events like config-changed
, relation-changed
, secret-changed
, and pebble-ready
Many existing charms use holistic event handling. A few examples are:
alertmanager-k8s
uses a_common_exit_hook
method to unify several event handlershello-kubecon
is a simple charm that handlesconfig-changed
andpebble-cready
holisticallyprometheus-k8s
uses a common_configure
method to handle various eventssdcore-gnbsim-k8s
also uses a common_configure
method
Which events can be handled holistically?
Only some events make sense to handle holistically. For example, remove
is triggered when a unit is about to be terminated, so it doesn’t make sense to handle it holistically.
Similarly, events like secret-expired
and secret-rotate
don’t make sense to handle holistically, because the charm must do something specific in response to the event. For example, Juju will keep triggering secret-expired
until the charm creates a new secret revision by calling event.secret.set_content()
This is very closely related to which events can be defer
red. A good rule of thumb is this: if an event can be deferred, it may make sense to handle it holistically.
On the other hand, if an event cannot be deferred, the charm cannot handle it holistically. This applies to action “events”, stop
, remove
, secret-expired
, secret-rotate
, and Ops-emitted events such as collect-status
