Deploy the Hockeypuck charm for the first time
What you’ll do
- Deploy the Hockeypuck charm
- Access the Hockeypuck web UI
By the end of this tutorial, you’ll have a working Hockeypuck server running on a Kubernetes cluster managed by Juju.
What you’ll need
- A machine with amd64 architecture.
- Juju 3.x installed.
- Juju MicroK8s controller created and active named
microk8s, with the MetalLB addon enabled (required for Traefik ingress to work).
All the requirements can be met using the Multipass charm-dev blueprint. Use the Multipass VM shell to run all commands in this tutorial.
For more information about how to install Juju, see Get started with Juju.
Set up a tutorial model
To easily clean up the resources and to separate your workload from the contents of this tutorial,
set up a new Juju model in the microk8s controller with the following command.
juju switch microk8s
juju add-model hockeypuck-tutorial
Deploy the hockeypuck-k8s charm
Deploy the Hockeypuck charm and PostgreSQL charm, and integrate them.
juju deploy hockeypuck-k8s --channel=2.2/edge --config metrics-port=9626 --config app-port=11371
juju deploy postgresql-k8s --channel 14/stable --trust
juju integrate hockeypuck-k8s postgresql-k8s
Wait for the charm to be active:
juju wait-for application hockeypuck-k8s
The Hockeypuck application supports only a single unit. Adding more units through the --num-units
flag will result in the application entering a blocked state. To achieve redundancy,
deploy multiple independent instances of Hockeypuck and configure peering between them.
Expose Hockeypuck webserver through ingress
Deploy the Traefik charm and integrate it with the Hockeypuck charm:
juju deploy traefik-k8s --channel=latest/edge --trust
juju integrate hockeypuck-k8s:ingress traefik-k8s
The Traefik charm must be deployed on the same Kubernetes cluster as Hockeypuck charm.
You can check the status with:
juju status --relations
After a few minutes, the deployment will be finished and all the units should be in the active status.
Run the following command to retrieve the URL for the Hockeypuck UI:
juju run traefik-k8s/0 show-proxied-endpoints --format=yaml
The output will be something similar to:
- task 2 on unit-traefik-k8s-0
Waiting for task 2...
traefik-k8s/0:
results:
proxied-endpoints: '{"traefik-k8s": {"url": "http://10.12.97.102"}, "hockeypuck-k8s":
{"url": "http://10.12.97.102/hockeypuck-tutorial-hockeypuck-k8s"}}'
return-code: 0
status: completed
timing:
completed: 2024-09-27 15:09:36 +0200 CEST
enqueued: 2024-09-27 15:09:35 +0200 CEST
started: 2024-09-27 15:09:35 +0200 CEST
unit: traefik-k8s/0
In this example, the URL to use in your browser will be http://10.12.97.102/hockeypuck-tutorial-hockeypuck-k8s.
The exact IP address may differ depending on your environment. You can now access your Hockeypuck server UI at this URL.
Cleaning up the environment
Congratulations! You have successfully finished the Hockeypuck charm tutorial. You can now remove the model environment that you’ve created using the following command.
juju destroy-model hockeypuck-tutorial --destroy-storage
