It’s a common pattern to test what events are emitted on a charm, to count them, or to verify that some event sequences are activated in unittests. Also you may want to check that the events have the expected API (e.g. that a custom event has a specific attribute…).
For that I wrote two little helper functions that temporarily monkey patch Framework.emit to grab all events being fired on the charm during a test.
You can do for example:
with capture_events(harness.charm, (RelationBrokenEvent, StorageEvent)) as captured:
harness.update_relation_data(0, 'remote', {'url': 'http://foo.bar'})
assert len(captured) == 2 # 2 events fired
assert isinstance(captured[0], RelationBrokenEvent)
Often you want to check a specific event has been fired:
capture() will check for you that exactly one event of a given type has been emitted in that frame.
with capture(harness.charm, UrlReadyEvent) as captured:
{'ingress': yaml.safe_dump({'url': url})})
event = captured.event
assert event.url == "foo.bar"
To start using these, do:
charmcraft fetch-lib charms.harness_extensions.v0.capture_events (source)
