Trying to setup graylog to use haproxy but the problem is that graylog default configuration is for 2 ports, 9000 and 9001. Here is the service.yaml file:
- service_name: apache
service_host: “0.0.0.0”
crts: [DEFAULT]
service_port: 443
service_options:
- balance leastconn
- reqadd X-Forwarded-Proto:\ https server_options:
- maxconn 100 cookie S{i} check
After setting up the relation and when I try to check if I can access graylog via https I get:
We are experiencing problems connecting to the Graylog server running on http://xxxxxxxx:9001/api/. Please verify that the server is healthy and working correctly.
You will be automatically redirected to the previous page once we can connect to the server.
This is the last response we received from the server:
Error message
Request has been terminated Possible causes: the network is offline, Origin is not allowed by Access-Control-Allow-Origin, the page is being unloaded, etc.
Original Request
GET http://xxxxxxxx:9001/api/system/sessions
Status code
undefined
Full error message
Error: Request has been terminated Possible causes: the network is offline, Origin is not allowed by Access-Control-Allow-Origin, the page is being unloaded, etc.
