I’m configuring grafana with a yaml like this to connect it to the company LDAP:
cat grafana-config.yaml
grafana:
ldap_config_flags: "{start_tls: false}"
I’m then configuring grafana:
juju config grafana --file grafana-config.yaml
It all seems to be OK, but, in the resulting config on the grafana/0 unit:
juju ssh grafana/0 sudo cat /etc/grafana/ldap.toml
[[servers]]
host = "example.com"
port = 363
start_tls = "False"
Which causes an error for grafana since “False” is a string, where the value should be a false (boolean)
logger=ldap t=2022-05-24T17:35:22.34+0000 lvl=info msg="LDAP enabled, reading config file" file=/etc/grafana/ldap.toml
logger=context traceID=00000000000000000000000000000000 userId=0 orgId=0 uname= t=2022-05-24T17:35:22.34+0000 lvl=eror msg="Error while trying to authenticate user" error="Failed to get LDAP config: Failed to load LDAP config file: toml: cannot load TOML value of type string into a Go boolean" remote_addr=10.201.46.102 traceID=00000000000000000000000000000000
Clearly, this is an error which prevents me from deploying this with LDAP connection.
I’m following the docs from Deploy Grafana using Charmhub - The Open Operator Collection
Here is the Bug #1975622 “grafana machine charm is not handling boolean conf...” : Bugs : Grafana Charm
… and a related bug: Bug #1975625 “Config references REAME which doesn't exist” : Bugs : Grafana Charm
