Relations
Overview
Relations provide a means to integrate applications and enable a simple communications channel. Grafana Agent Charmed Operator supports the following:
Provides
Logging provider
logging-provider:
interface: loki_push_api
Grafana Agent Charmed Operator may receive logs from any charm that supports the loki_push_api relation interface.
The information exchanged through the loki_push_api interface can be broken down into two parts:
- Grafana Agent charm provides an endpoint URL to receive log from Loki clients that relates with this charm.
- Grafana Agent charm may also receive alert rules which tell when to raise alerts. These rules are read from a directory named
loki_alert_rules, if present at the top level, within the client charm’s source (src) directory.
For instance let’s say that we have a Zinc Charmed Operator that implements the other side (requires) of the relation.
After deploying this charm, we can relate Grafana Agent and Zinc through loki_push_api relation interface:
juju relate grafana-agent-k8s:logging-provider zinc-k8s
Once the relation is established, Zinc charm can start sending logs to Grafana Agent charm.
Grafana dashboard
grafana-dashboard:
interface: grafana_dashboard
Over the grafana-dashboard relation using the grafana-dashboard interface, this Grafana Agent charm also provides meaningful dashboards about its metrics to be shown in a Grafana Charm .
In order to add these dashboards to Grafana all that is required is to relate the two charms in the following way:
juju relate \
grafana-agent-k8s:grafana-dashboard \
grafana-k8s:grafana-dashboard
Self metrics endpoint
self-metrics-endpoint:
interface: prometheus_scrape
This Grafana Agent charm may forward information about its metrics endpoint and associated alert rules to a Prometheus charm over the self-metrics-endpoint relation using the prometheus_scrape interface. In order for these metrics to be aggregated by the remote Prometheus charm all that is required is to relate the two charms as in:
juju relate \
grafana-agent-k8s:self-metrics-endpoint \
prometheus-k8s:metrics-endpoint
Requires
Logging consumer
logging-consumer:
Loki receives logs forwarded from Grafana Agent, aggregates and deduplicates them.
Grafana Agent Charmed Operator relates to Loki over the loki_push_api interface using the logging-consumer relation.
juju relate grafana-agent-k8s:logging-consumer loki-k8s
Metrics endpoint
metrics-endpoint:
Charms may forward information about their metrics endpoints and associated alert rules to the Grafana Agent charm over the metrics-endpoint relation using the prometheus_scrape interface.
juju relate grafana-agent-k8s:metrics-endpoint zinc-k8s
Charms that seek to provide metrics endpoints and alert rules must do so using the provided prometheus_scrape charm library. This library by implementing the metrics-endpoint relation, not only ensures that scrape jobs and alert rules are forward to Grafana Agent but also that these are updated any time the metrics provider charm is upgraded. For example new alert rules may be added or old ones removed by updating and releasing a new version of the metrics provider charm. While it is safe to update alert rules as desired, care must be taken when updating scrape job specifications as this has the potential to break the continuity of the scraped metrics time series. In particular changing the following keys in the scrape job can break time series continuity
job_namerelabel_configsmetrics_relabel_configs- Any label set by
static_configs
Evaluation of alert rules forwarded through the prometheus_scrape interface are automatically limited to the charmed application that provided these rules. This ensures that alert rule evaluation is scoped down to the charm providing the rules.
Send remote write
send-remote-write:
interface: prometheus_remote_write
Grafana Agent may forward client charms metrics and associated alert rules (that are received using the metrics-endpoint relation) to Prometheus using the prometheus_remote_write interface.
To do that you need to relate Grafana Agent with Prometheus:
juju relate grafana-agent-k8s:send-remote-write prometheus-k8s
Once these relations are established, you can check that by running:
juju status --relations
docs charm-dev microk8s/localhost 2.9.32 unsupported 17:55:18-03:00
grafana active 1 grafana-k8s edge 40 10.152.183.168 no
grafana-agent-k8s active 1 grafana-agent-k8s edge 11 10.152.183.123 no
loki-k8s waiting 1 loki-k8s edge 41 10.152.183.43 no
prometheus-k8s 2.33.5 active 1 prometheus-k8s candidate 55 10.152.183.128 no
zinc-k8s 0.2.8 active 1 zinc-k8s stable 26 10.152.183.247 no
grafana-agent-k8s/0* active idle 10.1.157.120
grafana/0* active idle 10.1.157.88
loki-k8s/0 active idle 10.1.157.86
prometheus-k8s/0* active idle 10.1.157.89
zinc-k8s/0* active idle 10.1.157.79
grafana-agent-k8s:grafana-dashboard grafana:grafana-dashboard grafana_dashboard regular
grafana-agent-k8s:logging-provider zinc-k8s:logging loki_push_api regular
grafana-agent-k8s:self-metrics-endpoint prometheus-k8s:metrics-endpoint prometheus_scrape regular
grafana:grafana grafana:grafana grafana_peers peer
loki-k8s:logging grafana-agent-k8s:logging-consumer loki_push_api regular
prometheus-k8s:prometheus-peers prometheus-k8s:prometheus-peers prometheus_peers peer
prometheus-k8s:receive-remote-write grafana-agent-k8s:send-remote-write prometheus_remote_write regular
zinc-k8s:metrics-endpoint grafana-agent-k8s:metrics-endpoint prometheus_scrape regular
