The grafana-agent charm has two limitations:
- Only one instance of the charm should be related to each application.
- Only one instance should run per machine.
Failing to enforce these constraints can lead to configuration conflicts and errors.
When applications allow multiple relations with different instances of grafana-agent (e.g., ga-one and ga-two), or several instances of grafana-agent are running in the same machine, several issues can arise:
Single service and config file: Even if multiple
grafana-agentcharms are related, only one service and one configuration file are installed on the machine, overwritten by all related charms. -
Conflicting confinement settings: If different
grafana-agentinstances use different confinement types (classicvsstrict), the snap will apply only one type, potentially causing inconsistencies. -
Errors when removing relations: Removing a relation may uninstall the
grafana-agentsnap entirely, leaving other related charms in an error state as they attempt to manage a service that no longer exists.
More information about this, can be found in this post.
Recommended Implementation and Safeguards
Applications should use a
limitin theirmetadata.yaml/charmcraft.yamlto restrict relations to only one instance ofgrafana-agent.cos-agent: interface: cos_agent limit: 1 -
Ensure that only one
grafana-agentinstance runs per machine to avoid configuration conflicts and unexpected behaviour. -
Two probes (in
draftstate right now) can be executed in order to verify whether only onegrafana-agentis related to a charm or only onegrafana-agentdeployed in a machine:juju export-bundle | ./probe_bundle.py juju status --format=yaml | ./probe_status.py
Following these practices ensures stable and predictable deployments in production environments.
