Charmed GLAuth K8s Tutorial
This tutorial aims to provide a general walkthrough to set up a fully working
GLAuth server using glauth-k8s charmed operator, MicroK8s, and Juju.
Set up the environment
Follow this guide to bootstrap a MicroK8s cloud running a Juju controller.
Create a Juju model:
juju add-model dev
Deploy prerequisite charmed operators
The glauth-k8s charmed operator requires the following charmed operators
deployed in the MicroK8s cluster:
juju deploy postgresql-k8s --channel 14/stable --trust
Deploy glauth-k8s charmed operator
The glauth-k8s charmed operator can be deployed as follows:
juju deploy glauth-k8s --channel edge --trust
Integrate with other charmed operators
The glauth-k8s charmed operator needs to integrate with the postgresql-k8s
and self-signed-certificates charmed operators to reach active state:
juju integrate glauth-k8s postgresql-k8s
juju integrate glauth-k8s self-signed-certificates
The glauth-k8s charmed operator offers the ldap integration with any LDAP
client charmed operator following the ldap interface protocol. Assuming we
have deployed such a client charmed operator, we can proceed to integrate it
with the glauth-k8s:
juju integrate <client-charm>:ldap glauth-k8s:ldap
The GLAuth supports the StartTLS operation, and the glauth-k8s charmed
operator enables it by default. In order to allow the client to trust the
self-signed certificates, we need to integrate the client charmed operator with
the glauth-k8s charmed operator for the certificate_transfer interface
protocol:
juju integrate <client-charm>:send-ca-cert glauth-k8s:send-ca-cert
Furthermore,
the glauth-utils charmed operator allows
us to apply data changes by using
the LDIF. To integrate with
the glauth-utils:
juju deploy glauth-utils --channel edge --trust
juju integrate glauth-k8s glauth-utils
A sample of supported LDIF content records can be found here.
We now should be able to reach to the following deployment status:
$ juju status --relations
dev microk8s-localhost microk8s/localhost 3.2.0 unsupported 16:12:33Z
client active 1 client 0 10.152.183.78 no
glauth-k8s active 1 glauth-k8s edge 13 10.152.183.231 no
glauth-utils active 1 glauth-utils edge 4 10.152.183.26 no
postgresql-k8s 14.10 active 1 postgresql-k8s 14/stable 193 10.152.183.163 no Primary
self-signed-certificates active 1 self-signed-certificates stable 72 10.152.183.21 no
client/0* active idle 10.1.48.115
glauth-k8s/0* active idle 10.1.48.96
glauth-utils/0* active idle 10.1.48.107
postgresql-k8s/0* active idle 10.1.48.77 Primary
self-signed-certificates/0* active idle 10.1.48.86
glauth-k8s:glauth-auxiliary glauth-utils:glauth-auxiliary glauth_auxiliary regular
glauth-k8s:glauth-peers glauth-k8s:glauth-peers glauth_peers peer
glauth-k8s:ldap client:ldap ldap regular
glauth-k8s:send-ca-cert client:send-ca-cert certificate_transfer regular
postgresql-k8s:database glauth-k8s:pg-database postgresql_client regular
postgresql-k8s:database-peers postgresql-k8s:database-peers postgresql_peers peer
postgresql-k8s:restart postgresql-k8s:restart rolling_op peer
postgresql-k8s:upgrade postgresql-k8s:upgrade upgrade peer
self-signed-certificates:certificates glauth-k8s:certificates tls-certificates regular
Tear down the environment
Remove the dev Juju model:
juju destroy-model dev
