Overview
The glance charm deploys Glance, the core OpenStack service that acts as the central repository for virtual machine (VM) images. The charm works alongside other Juju-deployed OpenStack services.
Important: This documentation supports version 3.x of the Juju client.
See the OpenStack Charm guide if you are using the
2.9.x client.
Usage
Configuration
This section covers common and/or important configuration options. See file
config.yaml for the full list of options, along with their descriptions and
default values. See the Juju documentation for details
on configuring applications.
openstack-origin
The openstack-origin option states the software sources. A common value is an
OpenStack UCA release (e.g. ‘cloud:bionic-ussuri’ or ‘cloud:focal-victoria’).
See Ubuntu Cloud Archive. The underlying host’s existing apt
sources will be used if this option is not specified (this behaviour can be
explicitly chosen by using the value of ‘distro’).
pool-type
The pool-type option dictates the Ceph storage pool type. See sections ‘Ceph
pool type’ and ‘Ceph backed storage’ for more information.
Deployment
This section includes five different deployment scenarios (with their respective backends). Each scenario requires these applications to be present: keystone, nova-cloud-controller, nova-compute, and a cloud database.
Note: The database application is determined by the series. Prior to focal percona-cluster is used, otherwise it is mysql-innodb-cluster. In the example deployments below mysql-innodb-cluster has been chosen.
Ceph-backed storage
Ceph is the recommended storage backend solution for Glance. The steps below assume a pre-existing Ceph cluster (see the ceph-mon and ceph-osd charms).
Here, Glance is deployed to a new container on machine ‘1’ and related to the Ceph cluster via the ceph-mon charm:
juju deploy --to lxd:1 glance
juju integrate glance:ceph ceph-mon:client
Proceed with a group of commands common to all four scenarios:
juju integrate glance:identity-service keystone:identity-service
juju integrate glance:image-service nova-cloud-controller:image-service
juju integrate glance:image-service nova-compute:image-service
juju deploy mysql-router glance-mysql-router
juju integrate glance-mysql-router:db-router mysql-innodb-cluster:db-router
juju integrate glance-mysql-router:shared-db glance:shared-db
This configuration can be used to support Glance in HA/scale-out deployments.
Note: In this scenario Glance acts as a Ceph client, which requires L3 network connectivity to Ceph monitors and OSDs. For MAAS-based deployments this can be addressed with network spaces (see section ‘Network spaces’ below).
Object storage-backed storage
Glance can use Object storage as its storage backend. OpenStack Swift, Ceph RADOS Gateway, and external S3 are supported, and all resulting configurations can be used to support Glance in HA/scale-out deployments.
Swift
The steps below assume a pre-existing Swift deployment (see the swift-proxy and swift-storage charms).
Here, Glance is deployed to a new container on machine ‘1’ and related to Swift via the swift-proxy charm:
juju integrate glance:object-store swift-proxy:object-store
Proceed with the common group of commands from the Ceph scenario.
Ceph RADOS Gateway
The steps below assume a pre-existing Ceph RADOS Gateway deployment (see the ceph-radosgw charm).
Here, Glance is deployed to a new container on machine ‘1’ and related to the ceph-radosgw application:
juju integrate glance:object-store ceph-radosgw:object-store
External S3
The step below assumes an external and pre-existing S3 compatible server available.
S3 server information can be passed via charm config options:
juju config glance \
s3-store-host='http://my-object-storage.example.com:8080' \
s3-store-access-key='ACCESS_KEY' \
s3-store-secret-key='SECRET_KEY' \
s3-store-bucket='BUCKET_NAME'
Note: The S3 backend is supported starting with OpenStack Ussuri. Enabling S3 backend overrides
expose-image-locationsas false not to expose S3 credentials through Glance API.
Cinder LVM-backed storage
Glance can also use Cinder LVM-backed storage as its storage backend, the configuration option cinder-volume-types can be used to specify the volume types in Cinder. The steps below assume a pre-existing Cinder LVM-backed deployment (see the cinder and cinder-lvm charms).
Here, Glance is deployed to machine ‘1’ and related to Cinder:
juju deploy --to 1 glance
juju integrate cinder:image-service glance:image-service
juju integrate cinder:cinder-volume-service glance:cinder-volume-service
Note: To support Cinder LVM-backed storage, Glance unit should be deployed on a baremetal machine or a virtual machine.
Local storage
Glance can simply use the storage available on the application unit’s machine to store image data. Here, Glance is deployed to a new container on machine ‘1’:
Multiple backends
Multiple storage backend support allows for one backend of each type:
- Ceph
- Swift (includes Ceph RADOS Gateway)
- S3
- Cinder
- local
With multiple backends configured, the cloud operator can specify, at image
upload time, which backend will be used to store the image. This is done by
using the --store option to the glance CLI client:
glance image-create --store <backend-name> ...
The default order of precedence is given by the following backend names: ‘ceph’, ‘swift’, ‘s3’, ‘cinder’, and then ‘local’.
Important: The backend name of ‘swift’ denotes both object storage solutions: Swift and Ceph RADOS Gateway. Only one of these solutions can therefore be used.
Actions
This section covers Juju actions supported by the charm.
Actions allow specific operations to be performed on a per-unit basis. To
display action descriptions run juju actions --schema glance. If the charm is
not deployed then see file actions.yaml.
openstack-upgradepauseresumesecurity-checklist
Ceph pool type
Ceph storage pools can be configured to ensure data resiliency either through
replication or by erasure coding. This charm supports both types via the
pool-type configuration option, which can take on the values of ‘replicated’
and ‘erasure-coded’. The default value is ‘replicated’.
For this charm, the pool type will be associated with Glance images.
Note: Erasure-coded pools are supported starting with Ceph Luminous.
Replicated pools
Replicated pools use a simple replication strategy in which each written object is copied, in full, to multiple OSDs within the cluster.
The ceph-osd-replication-count option sets the replica count for any object
stored within the ‘glance’ rbd pool. Increasing this value increases data
resilience at the cost of consuming more real storage in the Ceph cluster. The
default value is ‘3’.
Important: The
ceph-osd-replication-countoption must be set prior to adding the relation to the ceph-mon (or ceph-proxy) application. Otherwise, the pool’s configuration will need to be set by interfacing with the cluster directly.
Erasure coded pools
Erasure coded pools use a technique that allows for the same resiliency as replicated pools, yet reduces the amount of space required. Written data is split into data chunks and error correction chunks, which are both distributed throughout the cluster.
Note: Erasure coded pools require more memory and CPU cycles than replicated pools do.
When using erasure coded pools for Glance images two pools will be created: a
replicated pool (for storing RBD metadata) and an erasure coded pool (for
storing the data written into the RBD). The ceph-osd-replication-count
configuration option only applies to the metadata (replicated) pool.
Erasure coded pools can be configured via options whose names begin with the
ec- prefix.
Important: It is strongly recommended to tailor the
ec-profile-kandec-profile-moptions to the needs of the given environment. These latter options have default values of ‘1’ and ‘2’ respectively, which result in the same space requirements as those of a replicated pool.
See Ceph Erasure Coding in the OpenStack Charms Deployment Guide for more information.
Ceph BlueStore compression
This charm supports BlueStore inline compression
for its associated Ceph storage pool(s). The feature is enabled by assigning a
compression mode via the bluestore-compression-mode configuration option. The
default behaviour is to disable compression.
The efficiency of compression depends heavily on what type of data is stored in the pool and the charm provides a set of configuration options to fine tune the compression behaviour.
Note: BlueStore compression is supported starting with Ceph Mimic.
High availability
When more than one unit is deployed with the hacluster application the charm will bring up an HA active/active cluster.
There are two mutually exclusive high availability options: using virtual IP(s) or DNS. In both cases the hacluster subordinate charm is used to provide the Corosync and Pacemaker backend HA functionality.
See OpenStack high availability in the OpenStack Charms Deployment Guide for details.
Important: Glance in an HA configuration must be backed by either Ceph or Swift.
Glance metering
Glance metering can be achieved with Ceilometer. The rabbitmq-server and ceilometer-agent applications are required to be present.
Assuming Glance is deployed, add two relations:
juju integrate glance:amqp rabbitmq-server:amqp
juju integrate glance:amqp ceilometer-agent:amqp
juju integrate glance:juju-info ceilometer-agent:container
Network spaces
This charm supports the use of Juju network spaces. This feature optionally allows specific types of the application’s network traffic to be bound to subnets that the underlying hardware is connected to.
Note: Spaces must be configured in the backing cloud prior to deployment.
API endpoints can be bound to distinct network spaces supporting the network separation of public, internal and admin endpoints.
Glance acts as a Ceph client and needs IP connectivity to Ceph monitors and OSDs. Binding the ceph endpoint to a space can solve this problem in case monitors and OSDs are located on a single L2 broadcast domain (if they are not, static or dynamic routes need to be used in addition to spaces).
Access to the underlying MySQL instance can also be bound to a specific space using the shared-db relation.
To use this feature, use the --bind option when deploying the charm:
juju deploy glance --bind \
"public=public-space \
internal=internal-space \
admin=admin-space \
shared-db=internal-space \
ceph=ceph-access-space"
Alternatively, these can also be provided as part of a juju native bundle configuration:
glance:
charm: cs:xenial/glance
num_units: 1
bindings:
public: public-space
admin: admin-space
internal: internal-space
shared-db: internal-space
ceph: ceph-access-space
Note: Existing glance units configured with the
os-admin-network,os-internal-network, oros-public-networkoptions will continue to honour them. Furthermore, these options override any space bindings, if set.
Policy overrides
Policy overrides is an advanced feature that allows an operator to override the default policy of an OpenStack service. The policies that the service supports, the defaults it implements in its code, and the defaults that a charm may include should all be clearly understood before proceeding.
Caution: It is possible to break the system (for tenants and other services) if policies are incorrectly applied to the service.
Policy statements are placed in a YAML file. This file (or files) is then (ZIP) compressed into a single file and used as an application resource. The override is then enabled via a Boolean charm option.
Here are the essential commands (filenames are arbitrary):
zip overrides.zip override-file.yaml
juju attach-resource glance policyd-override=overrides.zip
juju config glance use-policyd-override=true
See Policy overrides in the OpenStack Charms Deployment Guide for a thorough treatment of this feature.
Documentation
The OpenStack Charms project maintains two documentation guides:
- OpenStack Charm Guide: for project information, including development and support notes
- OpenStack Charms Deployment Guide: for charm usage information
Bugs
Please report bugs on Launchpad.
Navigation
| Level | Path | Navlink |
| 1 | Home |
