Deploy the GitHub runner image builder for the first time
This quick start guide will help you deploy the GitHub Runner Image Builder charm in OpenStack mode.
What you’ll do
- Deploy the charm.
- Integrate with GitHub runners.
Requirements
- A working station, e.g., a laptop, with amd64 architecture.
- Juju 3 installed and bootstrapped to a LXD controller. You can accomplish this process by using a Multipass VM as outlined in this guide: Set up your test environment
- A running instance of OpenStack.
Steps
Shell into the Multipass VM
NOTE: If you’re working locally, you don’t need to do this step.
To be able to work inside the Multipass VM first you need to log in with the following command:
multipass shell my-juju-vm
Deploy the GitHub runner charm in OpenStack mode.
Deploy the GitHub runner image builder charm. For information on OpenStack credentials, refer to the official OpenStack documentation.
OPENSTACK_AUTH_URL=<openstack-auth-url, e.g. http://my-openstack-deployment/openstack-keystone>
OPENSTACK_PASSWORD=<openstack project password>
OPENSTACK_PROJECT_DOMAIN_NAME=<openstack project domain name>
OPENSTACK_PROJECT_NAME=<openstack project name>
OPENSTACK_USER_DOMAIN_NAME=<openstack user domain name>
OPENSTACK_USERNAME=<openstack username>
juju deploy github-runner-image-builder \
--config openstack-auth-url=$OPENSTACK_AUTH_URL \
--config openstack-password=$OPENSTACK_PASSWORD \
--config openstack-project-domain-name=$OPENSTACK_PROJECT_DOMAIN_NAME \
--config openstack-project-name=$OPENSTACK_PROJECT_NAME \
--config openstack-user-domain-name=$OPENSTACK_USER_DOMAIN_NAME \
--config openstack-user-name=$OPENSTACK_USERNAME
- Verify that the image is being built via Juju logs:
juju debug-log --include=github-runner-image-builder/0
- Verify that the image is successfully built.
openstack image list | grep noble-x64
juju integrate github-runner-image-builder github-runner
Cleanup
- Remove the github-runner-image-builder charm
juju remove-application github-runner-image-builder
- If you used Multipass, to remove the Multipass instance you created for this tutorial, use the following command.
multipass delete --purge my-juju-vm
- Remove the images built by the charm
openstack image list -f json | jq -r '.[] | select(.Name | contains("jammy-x64")) | .ID' | xargs -r openstack image delete
