github-runner docs: Token scopes
Token scopes
In order to use the GitHub runner charm, a personal access token with the necessary permissions is required.
Fine grained access token scopes
Note: In addition to having a token with the necessary permissions, the user who owns the token also must have admin access to the organisation or repository.
Organizational runners
The following are the permissions scopes required for the GitHub runners when registering as an organisational runner.
Organisation:
  • Self-hosted runners: read & write
Repository:
  • Actions: read (required if COS integration is enabled and private repositories exist)
  • Administration: read
Repository runners
The following are the permissions scopes required for the GitHub runners when registering as an repository runner.
  • Actions: read (required if COS integration is enabled and the repository is private)
  • Administration: read & write
  • Metadata: read
Personal access token scopes
Depending on whether the charm is used for GitHub organisations or repositories, the following scopes should be selected when creating a personal access token.
To use this charm for GitHub organisations, the following scopes should be selected:
  • repo
  • admin:org
Repository runners
To use this charm for GitHub repositories, the following scopes should be selected:
  • repo
