github-runner docs: Security in GitHub runner charm
This document describes the security design of the GitHub runner charm. The charm manages a set of GitHub self-hosted runners. The GitHub self-hosted runners allow CI/CD jobs on GitHub to run on virtual machines managed by the charm. The charm supports various features with security implications.
Remote code execution risk
The charm manages GitHub self-hosted runners to run GitHub Actions jobs. This allows users on GitHub to execute code on the servers hosting the runners, which poses a remote code execution risk if the code is not trusted. Therefore, the charm should only spawn runners to trusted organizations or repositories.
For third-party contributions, the charm can integrate with the Repo Policy Compliance charm to manage the repository policy. With this integration, the self-hosted runner will not execute the GitHub jobs if the policy is not met. See working with outside collaborators for the recommended settings to ensure the code is reviewed by a trusted user prior to execution in the runner.
Good practices
  • Only register the GitHub self-hosted runners to a trusted organization or repository so that only workflows from trusted users are able to run on the runners.
  • For outside collaborators: Use the repo-policy-compliance charm with policy for outside collaborators to ensure the code executed in runners are reviewed by a trusted user.
Permission for GitHub app or personal access token
The charm interacts with GitHub via RESTful API. This requires a personal access token.
It is generally recommended to grant the minimal permissions necessary for security reasons. Use a fine-grained token to control the scope of permission. See token scopes for more information.
Good practices
  • Use a fine-grained personal access token.
  • Give the minimal permission required.
OpenStack project management
The charm spawns OpenStack servers to host the GitHub self-hosted runner application. Since the GitHub jobs run within the OpenStack servers, it is recommended to isolate these OpenStack servers in its own OpenStack project. This prevents GitHub jobs from accessing other resources outside of their own OpenStack project. See the OpenStack documentation on how to manage OpenStack projects and users. See spawning OpenStack runner for how to make the charm utilize the OpenStack user and project.
Good practices
  • Have a separate OpenStack user and OpenStack project for the self-hosted runner to use.
Proxied environment
It is common for enterprises to manage outgoing network traffic through HTTP(S) proxies. By funneling all outgoing traffic through a proxy, there is a single point to control and observe the network traffic for administrators. If the OpenStack server hosting the runners is in such an environment, the GitHub workflow would have to route all traffic through the HTTP(S) proxies. Many popular GitHub Actions were designed to be ran on the GitHub provided runners which is not in a proxied environment. Hence many GitHub Actions do not work with HTTP(S) proxies.
To address this issue, the charm utilizes aproxy, a service that routes outgoing network traffic to a configured endpoint. The charm uses aproxy to transparently route outgoing traffic through the configured HTTP(S) proxy, ensuring that GitHub Actions work out of the box in a proxied environment. Aproxy can be enabled via a charm configuration.
Good practices
  • Manage the outgoing network traffic with a HTTP(S) proxy.
  • Use aproxy to make GitHub Actions work transparently with a HTTP(S) proxy.
OpenStack server network traffic
The charm spawns OpenStack servers to host the GitHub self-hosted runner application. The charm has taken precautions to manage the access of the OpenStack servers hosting the runner application. An OpenStack security group is used to manage the egress and ingress traffic. The OpenStack server is able to:
  • Receive traffic on port 22: Needed for the charm to manage the OpenStack server.
  • Send traffic on port 10022: Needed for the integration with tmate-ssh-server charm.
Other OpenStack security rules can be enforced by the OpenStack host. Enabling all port for egress is a common default OpenStack security rule. The above network traffic rules are what the charm manages.
