github-runner docs: How to spawn OpenStack runner
The charm can be configured to use OpenStack cloud for creating runners. The charm must be deployed with the correct configuration, and once the OpenStack integration is enabled, the charm cannot be changed to use other virtualization methods.
Configuration
There are three configuration that the charm needs to be deployed with to enable OpenStack integration: openstack-clouds-yaml, openstack-flavor, and openstack-network.
Integration
The image will take about 10-15 minutes to build and be fully integrated. Deploy the github-runner-image-builder charm and wait for the image to be successfully provided via the relation data.
juju deploy github-runner-image-builder
juju integrate github-runner-image-builder github-runner
juju status github-runner
The image will take about 10-15 minutes to build and be ready via the relation.
OpenStack clouds.yaml
The openstack-clouds-yaml configuration contains the authorization information needed for the charm to log in to the OpenStack cloud. The first cloud in the clouds.yaml is used by the charm.
Here is a sample of the clouds.yaml:
clouds:
  cloud:
    auth:
      auth_url: https://keystone.cloud.com:5000/v3
      project_name: github-runner
      username: github-runner
      password: PASSWORD
      user_domain_name: Default
      project_domain_name: Default
    region_name: cloud
The clouds.yaml documentation is here.
OpenStack flavour
The openstack-flavor configuration sets the flavour used to create the OpenStack virtual machine when spawning new runners. The flavour is tied with the vCPU, memory, and storage. The flavours documentation is here.
OpenStack network
The openstack-network configuration sets the network used to create the OpenStack virtual machine when spawning new runners.
Note that the network should be configured to allow traffic from the charm deployment (Juju machine) to the OpenStack virtual machine, and traffic from the OpenStack virtual machine to GitHub.
The network documentation is here.
NOTE: The name of the application must not be longer than 48 characters. A valid runner name is 64 characters or less in length and does not include ‘"’, ‘/’, ‘:’, ‘<’, ‘>’, '', ‘|’, ‘*’ and ‘?’. 16 characters are reserved for Juju unit number, unique identifier and other information.
