How to set base image
This charm supports deploying the runners on different base images.
By using juju config
to change the
charm configuration labels, the runner
can be deployed with a different Ubuntu base image. Latest two LTS images “jammy” and “noble” are
supported. The default base image is “jammy”.
juju config <APP_NAME> base-image=<BASE_IMAGE_TAG_OR_NAME>
An example of a BASE_IMAGE_TAG_OR_NAME value would be “jammy”, “22.04”, “noble”, “24.04”.
