How to deploy on ARM64
The charm supports deployment on ARM64 machines. However, it should be noted that the ARM64 deployment currently only supports ARM64 bare-metal machines due to the limitations of nested virtualization on ARM64.
The following uses AWS’s m7g.metal instance to deploy the GitHub Runner on ARM64 architecture.
Requirements
- Juju with ARM64 bare metal instance availability.
- On AWS:
juju bootstrap aws <desired-controller-name>
- On AWS:
- GitHub Personal Access Token
- Repository to register the GitHub runners.
Deployment steps
Run the following command:
juju deploy github-runner \
--constraints="instance-type=a1.metal arch=arm64" \
--config token=<PERSONAL-ACCESS-TOKEN> --config path=<OWNER/REPO>
The units may take several minutes to settle. Furthermore, due to charm restart (kernel update), the Unit may become lost for a few minutes. This is an expected behavior and the unit should automatically re-register itself onto the Juju controller after a successful reboot.
Go to the repository > Settings (tab) > Actions (left menu dropdown) > Runners and verify that the runner has successfully registered and is online.
