How to change GitHub personal access token
This charm supports changing the GitHub personal access token (PAT) used.
Changing the token
Create a new GitHub Personal Access Token.
An example classic token scope for repository use:
repo
For managing token scopes (fine-grained token), refer to the token scopes Reference page.
By using juju config to change the charm configuration token the charm unregisters and removes the old self-hosted runners and instantiates new ones.
juju config <APP_NAME> token=<TOKEN>
