How to change GitHub personal access token
This charm supports changing the GitHub personal access token (PAT) used.
Personal access token scope
To use this charm for GitHub repositories, the following scopes should be selected:
repo
To use this charm for GitHub organisations, the following scopes should be selected:
repoadmin:org
Changing the token
By using juju config to change the charm configuration token the charm unregisters and removes the old self-hosted runners and instantiates new ones.
juju config <APP_NAME> token=<TOKEN>
