Getting started with the tutorial - stuck on kubeflow-volumes/0
Ubuntu 24.04.4 LTS. Old timer here. Starting with AI.
I know docker, no knowledge of kubernettes, starting with kubeflow tutorial (everything running but kubeflow-volumes/0). I get:
$ juju status | grep kubeflow-volumes
kubeflow-volumes           res:oci-image@2261827    waiting      1  kubeflow-volumes         1.8/stable       260                  no       waiting for container
kubeflow-volumes/0*           waiting   idle
kubeflow config from tutorial:
$ juju config kubeflow-volumes
application: kubeflow-volumes
application-config:
  juju-application-path:
    default: /
    description: the relative http path used to access an application
    source: default
    type: string
    value: /
  juju-external-hostname:
    description: the external hostname of an exposed application
    source: unset
    type: string
  kubernetes-ingress-allow-http:
    default: false
    description: whether to allow HTTP traffic to the ingress controller
    source: default
    type: bool
    value: false
  kubernetes-ingress-class:
    default: nginx
    description: the class of the ingress controller to be used by the ingress resource
    source: default
    type: string
    value: nginx
  kubernetes-ingress-ssl-passthrough:
    default: false
    description: whether to passthrough SSL traffic to the ingress controller
    source: default
    type: bool
    value: false
  kubernetes-ingress-ssl-redirect:
    default: false
    description: whether to redirect SSL traffic to the ingress controller
    source: default
    type: bool
    value: false
  kubernetes-service-annotations:
    description: a space separated set of annotations to add to the service
    source: unset
    type: attrs
  kubernetes-service-external-ips:
    description: list of IP addresses for which nodes in the cluster will also accept
      traffic
    source: unset
    type: string
  kubernetes-service-externalname:
    description: external reference that kubedns or equivalent will return as a CNAME
      record
    source: unset
    type: string
  kubernetes-service-loadbalancer-ip:
    description: LoadBalancer will get created with the IP specified in this field
    source: unset
    type: string
  kubernetes-service-loadbalancer-sourceranges:
    description: traffic through the load-balancer will be restricted to the specified
      client IPs
    source: unset
    type: string
  kubernetes-service-target-port:
    description: name or number of the port to access on the pods targeted by the
      service
    source: unset
    type: string
  kubernetes-service-type:
    description: determines how the Service is exposed
    source: unset
    type: string
  trust:
    default: false
    description: Does this application have access to trusted credentials
    source: default
    type: bool
    value: false
charm: kubeflow-volumes
settings:
  backend-mode:
    default: development
    description: Which mode out of `development` or `production` the backend server
      should use
    source: default
    type: string
    value: development
  port:
    default: 5000
    description: HTTP port
    source: default
    type: int
    value: 5000
  secure-cookies:
    default: false
    description: Whether cookies should require HTTPS
    source: default
    type: boolean
    value: false
  volume-viewer-image:
    default: filebrowser/filebrowser:v2.23.0
    description: Volume Viewer OCI Image (PVCViewer)
    source: default
    type: string
    value: filebrowser/filebrowser:v2.23.0
Never mind. Got it working. Now stuck on displaying the actual login page.
