Getting Started bootstrap fails
Running the Getting Started example on my Ubuntu 18.04 desktop fails.
lxd --version
4.3
juju --version
2.8.1-bionic-amd64
juju bootstrap localhost overlord --debug --show-log
It hangs at
Waiting for address
Attempting to connect to 10.212.226.31:22
I kill the ssh process. This is apparently a known bug. That allows it to proceed.
20:06:32 INFO  cmd bootstrap.go:384 Connected to 10.212.226.31
20:06:32 INFO  juju.cloudconfig userdatacfg_unix.go:570 Fetching agent: curl -sSfw 'agent binaries from %{url_effective} downloaded: HTTP %{http_code}; time %{time_total}s; size %{size_download} bytes; speed %{speed_download} bytes/s ' --retry 10 -o $bin/tools.tar.gz <[https://streams.canonical.com/juju/tools/agent/2.8.1/juju-2.8.1-ubuntu-amd64.tgz]>
20:06:32 INFO  cmd bootstrap.go:454 Running machine configuration script...
It hangs at that point.
I can login in to the instance like this:
lxc exec juju-065d0e-0 /bin/bash
Networking appears to be working okay. This works:
wget https://streams.canonical.com/juju/tools/agent/2.8.1/juju-2.8.1-ubuntu-amd64.tgz
Any idea why the machine configuration script is hanging?
Any proxy in the mix there?
What does the /var/log/juju logs tell you?
Hi, Erik!
No proxy, no. Well, there was, but I disabled it. Firewall also disabled. I don’t think it’s a networking error, since the container has access to the network. DNS works. I was able to download the file manually using wget, so the link is correct.
14:42:34 INFO  cmd bootstrap.go:454 Running machine configuration script...
Timeout, server 10.212.226.107 not responding.
14:44:34 ERROR juju.cmd.juju.commands bootstrap.go:783 failed to bootstrap model: subprocess encountered error code 255
14:44:34 DEBUG juju.cmd.juju.commands bootstrap.go:784 (error details: [{/build/snapcraft-juju-03af7d/parts/juju/src/cmd/juju/commands/bootstrap.go:877: failed to bootstrap model} {/build/snapcraft-juju-03af7d/parts/juju/src/environs/bootstrap/bootstrap.go:614: } {/build/snapcraft-juju-03af7d/parts/juju/src/environs/bootstrap/bootstrap.go:580: } {subprocess encountered error code 255}])
14:44:34 DEBUG juju.cmd.juju.commands bootstrap.go:1448 cleaning up after failed bootstrap
14:44:34 INFO  juju.provider.common destroy.go:21 destroying model "controller"
14:44:34 INFO  juju.provider.common destroy.go:32 destroying instances
14:44:37 INFO  juju.provider.common destroy.go:56 destroying storage
14:44:37 DEBUG juju.provider.lxd environ.go:248 removing instances: []
14:44:37 INFO  cmd supercommand.go:544 command finished
While it was hanging I looked in the process table, expecting to see the curl command, but it did not appear.
I don’t see any /var/log/juju log on the host machine or in the container.
Maybe I can figure out how to run the curl command from the command line in the container?
There is a lead. What’s that IP attached to?
That’s the ip address of the container. It’s different than the one above because I tried the process a second time to look for the /var/log/juju logs you referenced, and copied and pasted from that.
Hmmm. Maybe go back to why the initial ssh attempt fails. That is reported as a known bug, and the workaround is as I describe, killing the hung ssh process.
I assumed the curl process is supposed to be running on the container, right?
If the curl process in the container works, it proves networking works on a basic level.
It also proves that traffic from the container, to internet works.
I’d try to figure out why traffic from your client IP to the container fails.
If you start a new container and try ssh - vvv hostip, what happens then?
lxc exec xyz bash is not a test of the network in that direction so its not a good test.
On workstation, ssh appears to be authenticating correctly:
ssh -v -i /home/liam/.ssh/id_rsa ubuntu@10.212.226.95 /bin/bash
OpenSSH_7.6p1 Ubuntu-4ubuntu0.3, OpenSSL 1.0.2n  7 Dec 2017
debug1: Reading configuration data /home/liam/.ssh/config
debug1: /home/liam/.ssh/config line 1: Applying options for *
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to 10.212.226.95 [10.212.226.95] port 22.
debug1: Connection established.
debug1: identity file /home/liam/.ssh/id_rsa type 0
debug1: key_load_public: No such file or directory
debug1: identity file /home/liam/.ssh/id_rsa-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
debug1: match: OpenSSH_7.6p1 Ubuntu-4ubuntu0.3 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 10.212.226.95:22 as 'ubuntu'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: rsa-sha2-512
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ssh-rsa SHA256:R3tRGiBZcRBdNIt29bM71TtR1x4TQhBZCxUHgvMNq3E
The authenticity of host '10.212.226.95 (10.212.226.95)' can't be established.
RSA key fingerprint is SHA256:R3tRGiBZcRBdNIt29bM71TtR1x4TQhBZCxUHgvMNq3E.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '10.212.226.95' (RSA) to the list of known hosts.
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: Skipping ssh-dss key liam@gavilan - not in PubkeyAcceptedKeyTypes
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Offering public key: RSA SHA256:SmfnLruZf33JeaE89n/HdJuMmWiPIkqBnoLP9nucLdc /home/liam/.ssh/id_rsa
debug1: Server accepts key: pkalg rsa-sha2-512 blen 279
debug1: Authentication succeeded (publickey).
Authenticated to 10.212.226.95 ([10.212.226.95]:22).
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: pledge: network
On controller machine it looks like the shell is immediately getting closed:
root@juju-74e3f5-0:/var/log# tail auth.log
Aug  7 09:15:29 juju-74e3f5-0 sshd[323]: pam_unix(sshd:session): session opened for user ubuntu by (uid=0)
Aug  7 09:15:29 juju-74e3f5-0 systemd-logind[200]: New session 383 of user ubuntu.
Aug  7 09:15:29 juju-74e3f5-0 systemd: pam_unix(systemd-user:session): session opened for user ubuntu by (uid=0)
Aug  7 09:15:41 juju-74e3f5-0 sshd[936]: error: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
Aug  7 09:15:41 juju-74e3f5-0 sshd[936]: error: Could not load host key: /etc/ssh/ssh_host_ed25519_key
Aug  7 09:15:44 juju-74e3f5-0 sshd[936]: Accepted publickey for ubuntu from 10.212.226.1 port 43158 ssh2: RSA SHA256:SmfnLruZf33JeaE89n/HdJuMmWiPIkqBnoLP9nucLdc
Aug  7 09:15:44 juju-74e3f5-0 sshd[936]: pam_unix(sshd:session): session opened for user ubuntu by (uid=0)
Aug  7 09:15:44 juju-74e3f5-0 systemd-logind[200]: New session 385 of user ubuntu.
Aug  7 09:17:01 juju-74e3f5-0 CRON[8169]: pam_unix(cron:session): session opened for user root by (uid=0)
Aug  7 09:17:01 juju-74e3f5-0 CRON[8169]: pam_unix(cron:session): session closed for user root
However, the configuration process decided to continue this time. It still failed. I think either the controller’s https process wasn’t running, or there was a networking problem between workstation and controller.
ERROR Get "https://10.212.226.1:8443/1.0": Unable to connect to: 10.212.226.1:8443
11:15:07 INFO  juju.cmd supercommand.go:91 running juju [2.8.1 0 16439b3d1c528b7a0e019a16c2122ccfcf6aa41f gc go1.14.4]
11:15:07 DEBUG juju.cmd supercommand.go:92   args: []string{"/snap/juju/13324/bin/juju", "bootstrap", "localhost", "overlord", "--debug", "--show-log"}
11:15:07 DEBUG juju.container.lxd connection.go:167 using LXD snap socket: "/var/snap/lxd/common/lxd"
11:15:07 INFO  cmd provider.go:359 Resolved LXD host address on bridge lxdbr0: https://10.212.226.1:8443
11:15:07 INFO  cmd cloudcredential.go:47 updating credential store
11:15:07 DEBUG juju.cmd.juju.commands bootstrap.go:1153 authenticating with region "" and credential "localhost" ()
11:15:07 DEBUG juju.cmd.juju.commands bootstrap.go:1281 provider attrs: map[]
11:15:08 INFO  cmd authkeys.go:114 Adding contents of "/home/liam/.local/share/juju/ssh/juju_id_rsa.pub" to authorized-keys
11:15:08 INFO  cmd authkeys.go:114 Adding contents of "/home/liam/.ssh/id_dsa.pub" to authorized-keys
11:15:08 INFO  cmd authkeys.go:114 Adding contents of "/home/liam/.ssh/id_rsa.pub" to authorized-keys
11:15:08 DEBUG juju.cmd.juju.commands bootstrap.go:1340 preparing controller with config: map[agent-metadata-url: agent-stream:released apt-ftp-proxy: apt-http-proxy: apt-https-proxy: apt-mirror: apt-no-proxy: authorized-keys:ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDGvmMfSNBzzM4ZVWYPpIAxGjLvf0S5w2rX1UWGQhs+x0E6Ecj6YVA6D+BEhCetkbtn/gAEhny67TPUxupTNqpvgC7U6eha6oDesjNkH8xkZ3LaU6HX6Lf8K7fHh9cBgnf5UAxs1+xf9iKiIbu2vdagOmiQ3vkexx+4mfz7j64P/F4NR3e6feNmoWjV1z3qAkzOnHlxtsvGa++VVreFNLjanFDSnvaioirVRjQUN0Xv6wxSgoL/jL/F0Di2hZp6DKI9/4QdBvVHKiYiNEoYEV6vKGGPsurOC+qEKkYJ7yGYL7KA2oMbDS8JcnrColYVQeWncKb6x7QvHqKqedThijBt juju-client-key
ssh-dss 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 liam@gavilan
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDND4byhfzcDPzpw6bkaOH0uLENSTSBEFQVBP9kYc8ABnSyMVQEXYuFAwFGZQOF/kWFXNTcHy14g1QaOpzGsHnQpTKKhYnKDUp1PhgiCdTIz/g7BYBgP6JkNIXYv6+Wl/yOqfUD8UIaQ+kkFZu2Ltaj73St1RR9NoVZ3T/n5GTInecx/I71tgCdpr47BN8sZYVvVzanl9+6PYwBcDXZSV9+wpZaBohXgQi90T8biZTKtWk0J8Z0LOSERhyXB55fXCosf5wJevze0rLicOfWcuPM6kwPGuWdcHvdeudvyZ5KxZ1T7g30A2Q8uRmD6grfZ5Md/vG0PNjv2RvDuwo3wHAb liam@tesseract
 automatically-retry-hooks:true backup-dir: cloudinit-userdata: container-image-metadata-url: container-image-stream:released container-inherit-properties: container-networking-method: default-series:bionic default-space: development:false disable-network-management:false egress-subnets: enable-os-refresh-update:true enable-os-upgrade:true fan-config: firewall-mode:instance ftp-proxy: http-proxy: https-proxy: ignore-machine-addresses:false image-metadata-url: image-stream:released juju-ftp-proxy: juju-http-proxy: juju-https-proxy: juju-no-proxy:127.0.0.1,localhost,::1 logforward-enabled:false logging-config: lxd-snap-channel:latest/stable max-action-results-age:336h max-action-results-size:5G max-status-history-age:336h max-status-history-size:5G name:controller net-bond-reconfigure-delay:17 no-proxy:127.0.0.1,localhost,::1 provisioner-harvest-mode:destroyed proxy-ssh:false resource-tags: snap-http-proxy: snap-https-proxy: snap-store-assertions: snap-store-proxy: snap-store-proxy-url: ssl-hostname-verification:true test-mode:false transmit-vendor-metrics:true type:lxd update-status-hook-interval:5m uuid:09b96ec9-774c-4451-82d4-72a7ef74e3f5]
11:15:08 INFO  cmd bootstrap.go:763 Creating Juju controller "overlord" on localhost/localhost
11:15:08 INFO  juju.cmd.juju.commands bootstrap.go:832 combined bootstrap constraints:
11:15:08 DEBUG juju.environs.bootstrap bootstrap.go:308 model "controller" supports application/machine networks: false
11:15:08 DEBUG juju.environs.bootstrap bootstrap.go:310 network management by juju enabled: true
11:15:08 INFO  cmd bootstrap.go:352 Loading image metadata
11:15:08 INFO  cmd bootstrap.go:429 Looking for packaged Juju agent version 2.8.1 for amd64
11:15:08 INFO  juju.environs.bootstrap tools.go:81 looking for bootstrap agent binaries: version=2.8.1
11:15:08 DEBUG juju.environs.tools tools.go:102 finding agent binaries in stream: "released"
11:15:08 DEBUG juju.environs.tools tools.go:104 reading agent binaries with major.minor version 2.8
11:15:08 DEBUG juju.environs.tools tools.go:112 filtering agent binaries by version: 2.8.1
11:15:08 DEBUG juju.environs.tools tools.go:115 filtering agent binaries by series: bionic
11:15:08 DEBUG juju.environs.tools tools.go:118 filtering agent binaries by architecture: amd64
11:15:08 DEBUG juju.environs.tools urls.go:138 trying datasource "keystone catalog"
11:15:09 DEBUG juju.environs.simplestreams simplestreams.go:692 using default candidate for content id "com.ubuntu.juju:released:tools" are {20161007 mirrors:1.0 content-download streams/v1/cpc-mirrors.sjson []}
11:15:10 INFO  juju.environs.bootstrap tools.go:83 found 1 packaged agent binaries
11:15:10 INFO  cmd bootstrap.go:516 Starting new instance for initial controller
11:15:10 INFO  cmd environ.go:191 To configure your system to better support LXD containers, please see: https://github.com/lxc/lxd/blob/master/doc/production-setup.md
11:15:10 INFO  cmd bootstrap.go:177 Launching controller instance(s) on localhost/localhost...
11:15:10 DEBUG juju.provider.lxd environ_broker.go:37 StartInstance: "0", bionic
11:15:10 DEBUG juju.cloudconfig.instancecfg instancecfg.go:981 Setting numa ctl preference to false
11:15:10 DEBUG juju.environs imagemetadata.go:126 obtained image datasource "default ubuntu cloud images"
11:15:10 DEBUG juju.container.lxd connection.go:184 LXD requires https://, using: https://cloud-images.ubuntu.com/releases/
11:15:10 DEBUG juju.container.lxd image.go:61 Found image locally - "ubuntu-18.04-server-cloudimg-amd64-lxd.tar.xz" "0041760acce68c101aecc63372309733df5bb94bf180eb3d9a21ae26c304f536"
11:15:10 DEBUG juju.service discovery.go:63 discovered init system "systemd" from series "bionic"
11:15:10 DEBUG juju.provider.lxd environ_broker.go:222 LXD user data; 4102 bytes
11:15:10 INFO  juju.container.lxd container.go:220 starting new container "juju-74e3f5-0" (image "ubuntu-18.04-server-cloudimg-amd64-lxd.tar.xz")
11:15:10 DEBUG juju.container.lxd container.go:221 new container has profiles [default juju-controller]
11:15:15 DEBUG juju.container.lxd container.go:248 created container "juju-74e3f5-0", waiting for start...
11:15:18 INFO  juju.provider.lxd environ_broker.go:52 started instance "juju-74e3f5-0"
11:15:18 INFO  cmd bootstrap.go:274  - juju-74e3f5-0 (arch=amd64)
11:15:18 INFO  juju.environs.bootstrap bootstrap.go:899 newest version: 2.8.1
11:15:18 INFO  juju.environs.bootstrap bootstrap.go:914 picked bootstrap agent binary version: 2.8.1
11:15:18 INFO  cmd bootstrap.go:559 Installing Juju agent on bootstrap instance
11:15:19 INFO  cmd bootstrap.go:690 Fetching Juju Dashboard 0.2.0
11:15:19 DEBUG juju.cloudconfig.instancecfg instancecfg.go:981 Setting numa ctl preference to false
Waiting for address
Attempting to connect to 10.212.226.95:22
11:17:29 DEBUG juju.provider.common bootstrap.go:615 connection attempt for 10.212.226.95 failed: Timeout, server 10.212.226.95 not responding.
11:19:35 DEBUG juju.provider.common bootstrap.go:615 connection attempt for 10.212.226.95 failed: Timeout, server 10.212.226.95 not responding.
11:21:40 DEBUG juju.provider.common bootstrap.go:615 connection attempt for 10.212.226.95 failed: Timeout, server 10.212.226.95 not responding.
11:22:25 INFO  cmd bootstrap.go:384 Connected to 10.212.226.95
11:22:25 INFO  juju.cloudconfig userdatacfg_unix.go:570 Fetching agent: curl -sSfw 'agent binaries from %{url_effective} downloaded: HTTP %{http_code}; time %{time_total}s; size %{size_download} bytes; speed %{speed_download} bytes/s ' --retry 10 -o $bin/tools.tar.gz <[https://streams.canonical.com/juju/tools/agent/2.8.1/juju-2.8.1-ubuntu-amd64.tgz]>
11:22:25 INFO  cmd bootstrap.go:454 Running machine configuration script...
Cloud-init v. 20.2-45-g5f7825e2-0ubuntu1~18.04.1 running 'init-local' at Fri, 07 Aug 2020 09:15:20 +0000. Up 1.96 seconds.
Cloud-init v. 20.2-45-g5f7825e2-0ubuntu1~18.04.1 running 'init' at Fri, 07 Aug 2020 09:15:21 +0000. Up 3.53 seconds.
ci-info: ++++++++++++++++++++++++++++++++++++++Net device info++++++++++++++++++++++++++++++++++++++
ci-info: +--------+------+----------------------------+---------------+--------+-------------------+
ci-info: | Device |  Up  |          Address           |      Mask     | Scope  |     Hw-Address    |
ci-info: |  eth0  | True |       10.212.226.95        | 255.255.255.0 | global | 00:16:3e:de:08:4d |
ci-info: |  eth0  | True | fe80::216:3eff:fede:84d/64 |       .       |  link  | 00:16:3e:de:08:4d |
ci-info: |   lo   | True |         127.0.0.1          |   255.0.0.0   |  host  |         .         |
ci-info: |   lo   | True |          ::1/128           |       .       |  host  |         .         |
ci-info: +++++++++++++++++++++++++++++++Route IPv4 info+++++++++++++++++++++++++++++++
ci-info: +-------+--------------+--------------+-----------------+-----------+-------+
ci-info: | Route | Destination  |   Gateway    |     Genmask     | Interface | Flags |
ci-info: |   0   |   0.0.0.0    | 10.212.226.1 |     0.0.0.0     |    eth0   |   UG  |
ci-info: |   1   | 10.212.226.0 |   0.0.0.0    |  255.255.255.0  |    eth0   |   U   |
ci-info: |   2   | 10.212.226.1 |   0.0.0.0    | 255.255.255.255 |    eth0   |   UH  |
ci-info: +++++++++++++++++++Route IPv6 info+++++++++++++++++++
ci-info: +-------+-------------+---------+-----------+-------+
ci-info: | Route | Destination | Gateway | Interface | Flags |
ci-info: |   0   |  fe80::/64  |    ::   |    eth0   |   U   |
ci-info: |   2   |    local    |    ::   |    eth0   |   U   |
ci-info: |   3   |   ff00::/8  |    ::   |    eth0   |   U   |
Cloud-init v. 20.2-45-g5f7825e2-0ubuntu1~18.04.1 running 'modules:config' at Fri, 07 Aug 2020 09:15:24 +0000. Up 6.25 seconds.
+ install -D -m 644 /dev/null /var/lib/juju/nonce.txt
+ printf %s\n user-admin:bootstrap
Cloud-init v. 20.2-45-g5f7825e2-0ubuntu1~18.04.1 running 'modules:final' at Fri, 07 Aug 2020 09:15:27 +0000. Up 9.77 seconds.
Cloud-init v. 20.2-45-g5f7825e2-0ubuntu1~18.04.1 finished at Fri, 07 Aug 2020 09:15:28 +0000. Datasource DataSourceNoCloud [seed=/var/lib/cloud/seed/nocloud-net][dsmode=net].  Up 10.04 seconds
Logging to /var/log/cloud-init-output.log on the bootstrap machine
Regenerating SSH RSA host key
Generating public/private rsa key pair.
Your identification has been saved in /etc/ssh/ssh_host_rsa_key.
Your public key has been saved in /etc/ssh/ssh_host_rsa_key.pub.
The key fingerprint is:
SHA256:fGFp57g0jUVyaL6SbQHNSkwivdb06M83+rcMtVUz9T4 root@juju-74e3f5-0
The key's randomart image is:
+---[RSA 2048]----+
|    ...o.o..o   .|
|     ...= ==    o|
|       = B= o  oo|
|      o.+o+O   .+|
|     . .So*oo .Eo|
|        +o+o . o.|
|          o oo.  |
|          .+.oo. |
+----[SHA256]-----+
Generating public/private dsa key pair.
Your identification has been saved in /etc/ssh/ssh_host_dsa_key.
Your public key has been saved in /etc/ssh/ssh_host_dsa_key.pub.
SHA256:EmC/j4Ut6Hiqt/O6vjr7pl9S478bkQ8S8QHtiFi7yR0 root@juju-74e3f5-0
+---[DSA 1024]----+
|    =o.          |
| o o.o+          |
|. o Eo.*         |
| . +=.O S        |
|  +=.o X         |
|  o = o o        |
|=%XB. +o         |
+----[SHA256]-----+
Generating public/private ecdsa key pair.
Your identification has been saved in /etc/ssh/ssh_host_ecdsa_key.
Your public key has been saved in /etc/ssh/ssh_host_ecdsa_key.pub.
SHA256:Kri77pjGDcJD0eERSqfvXz6MhOAVlkm0ouFM5XtGqhs root@juju-74e3f5-0
+---[ECDSA 256]---+
| .+O=            |
|..B*o            |
|.=o+..           |
|=+o.+            |
|=oo+.o  S        |
|.=ooo. .         |
|oE=.o +.         |
| =oo.ooo         |
|++*o . ..        |
+----[SHA256]-----+
Running apt-get update
Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
Get:2 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Get:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:4 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Get:5 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages [8570 kB]
Get:6 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages [808 kB]
Get:7 http://security.ubuntu.com/ubuntu bionic-security/main Translation-en [254 kB]
Get:8 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [689 kB]
Get:9 http://security.ubuntu.com/ubuntu bionic-security/universe Translation-en [228 kB]
Get:10 http://security.ubuntu.com/ubuntu bionic-security/multiverse amd64 Packages [8112 B]
Get:11 http://security.ubuntu.com/ubuntu bionic-security/multiverse Translation-en [2852 B]
Get:12 http://archive.ubuntu.com/ubuntu bionic/universe Translation-en [4941 kB]
Get:13 http://archive.ubuntu.com/ubuntu bionic/multiverse amd64 Packages [151 kB]
Get:14 http://archive.ubuntu.com/ubuntu bionic/multiverse Translation-en [108 kB]
Get:15 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [1032 kB]
Get:16 http://archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages [84.7 kB]
Get:17 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1097 kB]
Get:18 http://archive.ubuntu.com/ubuntu bionic-updates/universe Translation-en [342 kB]
Get:19 http://archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 Packages [19.2 kB]
Get:20 http://archive.ubuntu.com/ubuntu bionic-updates/multiverse Translation-en [6712 B]
Get:21 http://archive.ubuntu.com/ubuntu bionic-backports/main amd64 Packages [7516 B]
Get:22 http://archive.ubuntu.com/ubuntu bionic-backports/main Translation-en [4764 B]
Get:23 http://archive.ubuntu.com/ubuntu bionic-backports/universe amd64 Packages [7736 B]
Get:24 http://archive.ubuntu.com/ubuntu bionic-backports/universe Translation-en [4588 B]
Fetched 18.5 MB in 15s (1204 kB/s)
Reading package lists...
Running apt-get upgrade
Building dependency tree...
Reading state information...
Calculating upgrade...
The following package was automatically installed and is no longer required:
  libfreetype6
Use 'sudo apt autoremove' to remove it.
The following packages will be upgraded:
  apport base-files iproute2 kmod libkmod2 libnss-systemd libpam-systemd
  libsystemd0 libudev1 python3-apport python3-problem-report systemd
  systemd-sysv udev
14 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 5636 kB of archives.
After this operation, 6144 B of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 base-files amd64 10.1ubuntu2.9 [59.9 kB]
Get:2 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libnss-systemd amd64 237-3ubuntu10.42 [105 kB]
Get:3 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libsystemd0 amd64 237-3ubuntu10.42 [208 kB]
Get:4 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libpam-systemd amd64 237-3ubuntu10.42 [107 kB]
Get:5 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 systemd amd64 237-3ubuntu10.42 [2914 kB]
Get:6 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 udev amd64 237-3ubuntu10.42 [1102 kB]
Get:7 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libudev1 amd64 237-3ubuntu10.42 [57.4 kB]
Get:8 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 kmod amd64 24-1ubuntu3.5 [88.8 kB]
Get:9 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libkmod2 amd64 24-1ubuntu3.5 [40.2 kB]
Get:10 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 systemd-sysv amd64 237-3ubuntu10.42 [15.2 kB]
Get:11 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 iproute2 amd64 4.15.0-2ubuntu1.2 [722 kB]
Get:12 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 python3-problem-report all 2.20.9-0ubuntu7.16 [10.7 kB]
Get:13 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 python3-apport all 2.20.9-0ubuntu7.16 [82.2 kB]
Get:14 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 apport all 2.20.9-0ubuntu7.16 [125 kB]
Fetched 5636 kB in 4s (1265 kB/s)
(Reading database ... 28739 files and directories currently installed.)
Preparing to unpack .../base-files_10.1ubuntu2.9_amd64.deb ...
Warning: Stopping motd-news.service, but it can still be activated by:
  motd-news.timer
Unpacking base-files (10.1ubuntu2.9) over (10.1ubuntu2.8) ...
Setting up base-files (10.1ubuntu2.9) ...
Installing new version of config file /etc/issue ...
Installing new version of config file /etc/issue.net ...
Installing new version of config file /etc/lsb-release ...
motd-news.service is a disabled or a static unit, not starting it.
Preparing to unpack .../libnss-systemd_237-3ubuntu10.42_amd64.deb ...
Unpacking libnss-systemd:amd64 (237-3ubuntu10.42) over (237-3ubuntu10.41) ...
Preparing to unpack .../libsystemd0_237-3ubuntu10.42_amd64.deb ...
Unpacking libsystemd0:amd64 (237-3ubuntu10.42) over (237-3ubuntu10.41) ...
Setting up libsystemd0:amd64 (237-3ubuntu10.42) ...
Preparing to unpack .../libpam-systemd_237-3ubuntu10.42_amd64.deb ...
Unpacking libpam-systemd:amd64 (237-3ubuntu10.42) over (237-3ubuntu10.41) ...
Preparing to unpack .../systemd_237-3ubuntu10.42_amd64.deb ...
Unpacking systemd (237-3ubuntu10.42) over (237-3ubuntu10.41) ...
Preparing to unpack .../udev_237-3ubuntu10.42_amd64.deb ...
Unpacking udev (237-3ubuntu10.42) over (237-3ubuntu10.41) ...
Preparing to unpack .../libudev1_237-3ubuntu10.42_amd64.deb ...
Unpacking libudev1:amd64 (237-3ubuntu10.42) over (237-3ubuntu10.41) ...
Setting up libudev1:amd64 (237-3ubuntu10.42) ...
Preparing to unpack .../kmod_24-1ubuntu3.5_amd64.deb ...
Unpacking kmod (24-1ubuntu3.5) over (24-1ubuntu3.4) ...
Preparing to unpack .../libkmod2_24-1ubuntu3.5_amd64.deb ...
Unpacking libkmod2:amd64 (24-1ubuntu3.5) over (24-1ubuntu3.4) ...
Setting up libkmod2:amd64 (24-1ubuntu3.5) ...
Setting up systemd (237-3ubuntu10.42) ...
Preparing to unpack .../systemd-sysv_237-3ubuntu10.42_amd64.deb ...
Unpacking systemd-sysv (237-3ubuntu10.42) over (237-3ubuntu10.41) ...
Preparing to unpack .../iproute2_4.15.0-2ubuntu1.2_amd64.deb ...
Unpacking iproute2 (4.15.0-2ubuntu1.2) over (4.15.0-2ubuntu1.1) ...
Preparing to unpack .../python3-problem-report_2.20.9-0ubuntu7.16_all.deb ...
Unpacking python3-problem-report (2.20.9-0ubuntu7.16) over (2.20.9-0ubuntu7.15) ...
Preparing to unpack .../python3-apport_2.20.9-0ubuntu7.16_all.deb ...
Unpacking python3-apport (2.20.9-0ubuntu7.16) over (2.20.9-0ubuntu7.15) ...
Preparing to unpack .../apport_2.20.9-0ubuntu7.16_all.deb ...
Unpacking apport (2.20.9-0ubuntu7.16) over (2.20.9-0ubuntu7.15) ...
Setting up libnss-systemd:amd64 (237-3ubuntu10.42) ...
Setting up kmod (24-1ubuntu3.5) ...
Setting up systemd-sysv (237-3ubuntu10.42) ...
Setting up iproute2 (4.15.0-2ubuntu1.2) ...
Setting up python3-problem-report (2.20.9-0ubuntu7.16) ...
Setting up udev (237-3ubuntu10.42) ...
update-initramfs: deferring update (trigger activated)
Setting up libpam-systemd:amd64 (237-3ubuntu10.42) ...
Setting up python3-apport (2.20.9-0ubuntu7.16) ...
Setting up apport (2.20.9-0ubuntu7.16) ...
apport-autoreport.service is a disabled or a static unit, not starting it.
Processing triggers for dbus (1.12.2-1ubuntu1.2) ...
Processing triggers for ureadahead (0.100.0-21) ...
Processing triggers for install-info (6.5.0.dfsg.1-2) ...
Processing triggers for plymouth-theme-ubuntu-text (0.9.3-1ubuntu7.18.04.2) ...
Processing triggers for libc-bin (2.27-3ubuntu1.2) ...
Processing triggers for systemd (237-3ubuntu10.42) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for initramfs-tools (0.130ubuntu3.9) ...
Installing curl, cpu-checker, bridge-utils, tmux, ubuntu-fan
curl is already the newest version (7.58.0-2ubuntu3.9).
curl set to manually installed.
  libfreetype6
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
  libfreetype6
The following additional packages will be installed:
  msr-tools
The following NEW packages will be installed:
  cpu-checker msr-tools
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 16.6 kB of archives.
After this operation, 62.5 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu bionic/main amd64 msr-tools amd64 1.3-2build1 [9760 B]
Get:2 http://archive.ubuntu.com/ubuntu bionic/main amd64 cpu-checker amd64 0.7-0ubuntu7 [6862 B]
Fetched 16.6 kB in 0s (89.0 kB/s)
Selecting previously unselected package msr-tools.
Preparing to unpack .../msr-tools_1.3-2build1_amd64.deb ...
Unpacking msr-tools (1.3-2build1) ...
Selecting previously unselected package cpu-checker.
Preparing to unpack .../cpu-checker_0.7-0ubuntu7_amd64.deb ...
Unpacking cpu-checker (0.7-0ubuntu7) ...
Setting up msr-tools (1.3-2build1) ...
Setting up cpu-checker (0.7-0ubuntu7) ...
  libfreetype6
Suggested packages:
  ifupdown
  bridge-utils
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 30.1 kB of archives.
After this operation, 102 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu bionic/main amd64 bridge-utils amd64 1.5-15ubuntu1 [30.1 kB]
Fetched 30.1 kB in 0s (209 kB/s)
Selecting previously unselected package bridge-utils.
(Reading database ... 28753 files and directories currently installed.)
Preparing to unpack .../bridge-utils_1.5-15ubuntu1_amd64.deb ...
Unpacking bridge-utils (1.5-15ubuntu1) ...
Setting up bridge-utils (1.5-15ubuntu1) ...
tmux is already the newest version (2.6-3ubuntu0.2).
tmux set to manually installed.
  libfreetype6
  libfreetype6
  ubuntu-fan
Need to get 34.7 kB of archives.
After this operation, 150 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu bionic/main amd64 ubuntu-fan all 0.12.10 [34.7 kB]
Fetched 34.7 kB in 0s (196 kB/s)
Selecting previously unselected package ubuntu-fan.
(Reading database ... 28781 files and directories currently installed.)
Preparing to unpack .../ubuntu-fan_0.12.10_all.deb ...
Unpacking ubuntu-fan (0.12.10) ...
Setting up ubuntu-fan (0.12.10) ...
Created symlink /etc/systemd/system/multi-user.target.wants/ubuntu-fan.service → /lib/systemd/system/ubuntu-fan.service.
Fetching Juju agent version 2.8.1 for amd64
Attempt 1 to download agent binaries from https://streams.canonical.com/juju/tools/agent/2.8.1/juju-2.8.1-ubuntu-amd64.tgz...
agent binaries from https://streams.canonical.com/juju/tools/agent/2.8.1/juju-2.8.1-ubuntu-amd64.tgz downloaded: HTTP 200; time 35.325944s; size 38345802 bytes; speed 1085514.000 bytes/s Agent binaries downloaded successfully.
f93bb296dd8550400e28ea2b50b19ef668e58c3f0aacdfe9b5cd87701c6ef8c8  /var/lib/juju/tools/2.8.1-bionic-amd64/tools.tar.gz
6b13aeeaae06163ca4070aaf82afd87f88479c68fc6cda733bbdceb4d3280bec  /var/lib/juju/gui/gui.tar.bz2
Installing Juju machine agent
2020-08-07 09:24:08 INFO juju.cmd supercommand.go:91 running jujud [2.8.1 0 16439b3d1c528b7a0e019a16c2122ccfcf6aa41f gc go1.14.4]
2020-08-07 09:24:08 DEBUG juju.cmd supercommand.go:92   args: []string{"/var/lib/juju/tools/2.8.1-bionic-amd64/jujud", "bootstrap-state", "--timeout", "20m0s", "--data-dir", "/var/lib/juju", "--debug", "/var/lib/juju/bootstrap-params"}
2020-08-07 09:24:28 DEBUG cmd supercommand.go:537 error stack:
/workspace/_build/src/github.com/juju/juju/container/lxd/server.go:96:
/workspace/_build/src/github.com/juju/juju/provider/lxd/server.go:204:
/workspace/_build/src/github.com/juju/juju/provider/lxd/environ.go:157:
/workspace/_build/src/github.com/juju/juju/provider/lxd/environ.go:80:
/workspace/_build/src/github.com/juju/juju/provider/lxd/provider.go:149:
/workspace/_build/src/github.com/juju/juju/cmd/jujud/agent/bootstrap.go:188:
2020-08-07 09:24:28 DEBUG juju.cmd.jujud main.go:257 jujud complete, code 0, err <nil>
11:24:28 ERROR juju.cmd.juju.commands bootstrap.go:783 failed to bootstrap model: subprocess encountered error code 1
11:24:28 DEBUG juju.cmd.juju.commands bootstrap.go:784 (error details: [{/build/snapcraft-juju-03af7d/parts/juju/src/cmd/juju/commands/bootstrap.go:877: failed to bootstrap model} {/build/snapcraft-juju-03af7d/parts/juju/src/environs/bootstrap/bootstrap.go:614: } {/build/snapcraft-juju-03af7d/parts/juju/src/environs/bootstrap/bootstrap.go:580: } {subprocess encountered error code 1}])
11:24:28 DEBUG juju.cmd.juju.commands bootstrap.go:1448 cleaning up after failed bootstrap
11:24:28 INFO  juju.provider.common destroy.go:21 destroying model "controller"
11:24:28 INFO  juju.provider.common destroy.go:32 destroying instances
11:24:31 INFO  juju.provider.common destroy.go:56 destroying storage
11:24:31 DEBUG juju.provider.lxd environ.go:248 removing instances: []
11:24:31 INFO  cmd supercommand.go:544 command finished
Hey.
Right, that error message suggests a networking issue between the container (10.212.226.96) and the host/workstation (10.212.226.1).
Maybe it’s a firewall configuration (I see you mentioned firewall is disabled, but just in case) or some configuration setting when running the lxd init step?
If you could try to launch another container and test it can access the host, say, run a python web server and try to connect to it; for example:
In the host:
$ python3 -m http.server # <port number, default 8000>
Serving HTTP on 0.0.0.0 port 8000 (http://0.0.0.0:8000/) ...
In the container:
$ curl 10.212.226.1:8000
If that works it might something with the specific port (8443) or Juju client/process serving that port?
You could also try on a fresh Ubuntu VM, to rule out particular settings in your workstation.
Hope this helps!
