How to Contribute
Overview
This document explains the processes and practices recommended for contributing enhancements to the Flask operator.
- Before developing enhancements to this charm, consider opening an issue to explain your use case.
- If you want to discuss your use-cases or proposed implementation, you can reach us at Canonical Mattermost public channel or Discourse.
- Familiarizing yourself with the Charmed Operator Framework will be beneficial when working on new features or bug fixes.
- All enhancements require a review before merging. Code reviews typically examine code quality, test coverage, and user experience for Juju operators of this charm.
- Please help us ensure easy-to-review branches by rebasing your pull request
branch onto the
mainbranch. This also avoids merge commits and creates a linear Git commit history. - For additional information on contributing, refer to our Contributing Guide.
Developing
Building from Source
To build and deploy the flask-k8s charm from source, follow the steps below.
Docker Image Build
Build your Flask application image, and to allow microk8s to pick up the locally built image, you must export the image and import it within microk8s.
docker save flask:test > flask.tar && microk8s import flask.tar
Build the Charm
Build the charm locally using charmcraft. It should output a .charm file.
charmcraft pack
Deploy Flask
Deploy the locally built Flask charm with the following command.
juju deploy ./flask-k8s_ubuntu-22.04-amd64_ubuntu-20.04-amd64.charm \
--resource flask-app-image=localhost:32000/flask:test \
--resource statsd-prometheus-exporter-image=prom/statsd-exporter
Monitor your local flask-k8s charm’s progress through the stages of the
deployment with juju status --watch 2s.
Testing
Use the following commands to run the tests:
tox: Runs all of the basic checks (lint,unit,static, andcoverage-report). -
tox -e fmt: Formats the code usingblackandisort. -
tox -e lint: Runs a range of static code analyses to check the code. -
tox -e static: Runs other checks such asbanditfor security issues. -
tox -e unit: Runs the unit tests. -
tox -e integration: Runs the integration tests. Integration tests require additional arguments depending on the test module.
Canonical Contributor Agreement
Canonical welcomes contributions to the Flask Operator. If you’re interested in contributing to the solution, please check out our contributor agreement.
