Flannel is a virtual network that gives a subnet to each host for use with container runtimes.
This charm will deploy flannel as a background service, and configure CNI for
use with flannel, on any principal charm that implements the
kubernetes-cni interface.
Usage
The flannel charm is a
subordinate.
This charm will require a principal charm that implements the kubernetes-cni
interface in order to properly deploy.
juju deploy flannel
juju deploy etcd
juju deploy kubernetes-control-plane
juju deploy kubernetes-worker
juju add-relation flannel etcd
juju add-relation flannel kubernetes-control-plane
juju add-relation flannel kubernetes-worker
Known Limitations
This subordinate does not support being co-located with other deployments of the flannel subordinate (to gain 2 vlans on a single application). If you require this support please file a bug.
This subordinate also leverages juju-resources, so it is currently only available on juju 2.0+ controllers.
