File 'tox.ini'
The tox.ini file in your charm’s root directory is a typical Tox configuration file.
See more: Tox | Configuration
This file is generated automatically by charmcraft init with the contents below:
 Copyright 2023 Ubuntu
# See LICENSE file for licensing details.
[tox]
no_package = True
skip_missing_interpreters = True
env_list = format, lint, static, unit
min_version = 4.0.0
[vars]
src_path = {tox_root}/src
tests_path = {tox_root}/tests
;lib_path = {tox_root}/lib/charms/operator_name_with_underscores
all_path = {[vars]src_path} {[vars]tests_path}
[testenv]
set_env =
    PYTHONPATH = {tox_root}/lib:{[vars]src_path}
    PYTHONBREAKPOINT=pdb.set_trace
    PY_COLORS=1
pass_env =
    PYTHONPATH
    CHARM_BUILD_DIR
    MODEL_SETTINGS
[testenv:format]
description = Apply coding style standards to code
deps =
    black
    ruff
commands =
    black {[vars]all_path}
    ruff --fix {[vars]all_path}
[testenv:lint]
description = Check code against coding style standards
deps =
    black
    ruff
    codespell
commands =
    # if this charm owns a lib, uncomment "lib_path" variable
    # and uncomment the following line
    # codespell {[vars]lib_path}
    codespell {tox_root}
    ruff {[vars]all_path}
    black --check --diff {[vars]all_path}
[testenv:unit]
description = Run unit tests
deps =
    pytest
    coverage[toml]
    -r {tox_root}/requirements.txt
commands =
    coverage run --source={[vars]src_path} \
                 -m pytest \
                 --tb native \
                 -v \
                 -s \
                 {posargs} \
                 {[vars]tests_path}/unit
    coverage report
[testenv:static]
description = Run static type checks
deps =
    pyright
commands =
    pyright {posargs}
[testenv:integration]
description = Run integration tests
deps =
    pytest
    juju
    pytest-operator
commands =
    pytest -v \
           -s \
           --tb native \
           --log-cli-level=INFO \
           {posargs} \
           {[vars]tests_path}/integration
