File 'manifest.yaml'
List of files in the charm project > manifest.yaml
See also: How to configure Charmcraft
The manifest.yaml file is generated automatically by the charmcraft tool when a charm or bundle is packed. It is used by Charmhub and charmcraft to identify the version, build time, OS name, and version at build time, as well as the architectures that the charm can run on. An example can be found here. This manifest contains a simplified version of the charmcraft.yaml file that is used to verify whether a machine charm is compatible with the running system.
