File 'LICENSE'
List of files in the charm project > LICENSE
The LICENSE file is the file where you specify the license you want to use for your charm.
Charmcraft pre-populates the LICENSE file with the Apache 2 license. Before publication, it is important that you consider the implications of this and select a license appropriate for your use case. If you’re not sure which license to select, choosealicense.com can help you. For most charms, we recommend Apache 2, as this will allow for simple modification, redistribution, and packaging by the Charmhub community.
