My question now is… how do I access to this app from the external IP from my ubuntu server? Do know any guide which explain this?
Another question how do I access to this app from the external IP from my ubuntu server?, if I want to access from a domaion (because I want to expose two containers to the 80 port, and I want that depending on the domain, goes to a different container_ip) how I do that? Do you know any guide which explain this?
Thanks a lot, I just need a little guide, and I am very lost with the networking related to external IPs.
Typically, you make an application available on a public IP by running the expose command. For example:
juju expose hello-juju
If Juju knows how to expose the charm on a public ip, it’ll do so.
Juju doesn’t handle the process of associating a domain with an application. It’s a feature that we’d like to add. For now, you’d need to register a domain name, then point it at the public IP of your application, as you normally would.
As I saw in the documentation, juju expose hello-juju is the way, as also you say, but I do not see any change. But If I access thought the kubernetes IP, I can see the container UP and running.
Hello @petevg, I have been working on this, and I would like to clarify what is happening to me.
I also created this post, just in case could be related in anyhow.
Question: Using LXD controller, when exposing, I do not make it work (or something I am doing wrong)
Deploy and Expose
administrator@master-ubuntu:~$ juju deploy hello-juju
Located charm "cs:hello-juju-4".
Deploying charm "cs:hello-juju-4".
administrator@master-ubuntu:~$ juju expose hello-juju
administrator@master-ubuntu:~$ juju status
lxd-staging-model lxd-staging localhost/localhost 2.8.7 unsupported 21:10:08Z
hello-juju active 1 hello-juju jujucharms 4 ubuntu exposed
hello-juju/0* active idle 1 10.231.102.211 80/tcp Serving HTTP from gunicorn
1 started 10.231.102.211 juju-c5a3b6-1 bionic Running
administrator@master-ubuntu:~$ curl 10.231.102.211
Hello Juju!
Here comes the problem.
administrator@master-ubuntu:~$ curl 192.168.2.5
curl: (7) Failed to connect to 192.168.2.5 port 80: Connection refused
administrator@master-ubuntu:~$ curl localhost
curl: (7) Failed to connect to localhost port 80: Connection refused
How can I make this pod available to be exposed from outside?
I am a network administrator and in fact, ingress, networking, domains and certs is the most complicated part in finding on Kubernetes and Juju. If anyone reading can give clear resources about this to learn practically and in deep I would much appreciate.
