Integrating with the metrics endpoint interface allows you to, through a minimal amount of code, enable your charm to get scraped by a charm like prometheus-k8s or grafana-agent-k8s.
- A charm with a workload that exposes a metrics endpoint.
- A Juju deployment with COS Lite deployed.
Fetch the Library
Fetch the prometheus_scrape library using the charmcraft command:
charmcraft fetch-lib charms.prometheus_k8s.v0.prometheus_scrape
Import the Library
At the top of your charm’s src/charm.py source file, add an import of the charm library you just imported.
from charms.prometheus_k8s.v0.prometheus_scrape import MetricsEndpointProvider
Using the constructor
In the __init__ function of your charm class, instantiate the MetricsEndpointProvider. In its simplest form, where the workload exposes its metrics endpoint over port 80, with the path /metrics.
class ScrapableCharm:
def __init__(self, *args):
self.metrics_endpoint = MetricsEndpointProvider(self)
To override the default targets or the metrics path, you may then supply them as additional arguments while doing the instantiation.
self.metrics_endpoint_provider = MetricsEndpointProvider(
self,
jobs=[{
"metrics_path": "/my/strange/metrics/path",
"static_configs": [{"targets": ["*:8080"]}],
Declaring the relation
As a last step, you need to declare the relation in your charms metadata.yaml file.
provides:
metrics-endpoint:
interface: prometheus_scrape
Congratulations! You will now be able to add an integration between your charm and a scraper! ![]()
