Event 'secret-rotate'
Event > List of events > Secret events > secret-changed
This feature is scheduled for release in ops 2.0, and is only available when using Juju 3.0.2 or greater.
The secret-rotate event is fired on the owner of a secret every time the rotation period elapses (and the event will keep firing until the owner rotates the secret).
Upon receiving that event the owner should create a new secret revision. Once that is done, all observers will be notified that a new revision is present by means of a secret-changed event.
If the owner did not specify a rotation policy upon creating the secret, this event will never be fired for that secret.
Emission sequence
Like all secret events, secret-rotate is automatically triggered by Juju. When the owner adds the secret, it can select what the rotation period will be: hourly, daily, weekly, monthly, quarterly, or yearly.
Scenario Example Code Resulting Events
Owner creates a secret rotating daily n/a (every day) secret-rotate
Observing this event in ops
In the Python Operator Framework, you can observe the event like you would any other:
self.framework.observe(charm.on.secret_rotate, self._on_secret_rotate)
The SecretRotateEvent exposes no additional attributes on top of those it inherits from SecretEvent.
A typical implementation of _on_secret_rotate might look like this:
def _on_secret_rotate(self, event: SecretRotateEvent):
    secret = event.secret
    # create a new revision
    secret.set_content({'username': secret.get_content()['username'],
                        'password': self._generate_new_password()})
Updated with the latest terminology and API changes, as well as various style tweaks.
Can we add example code for creating a secret please? :slight_smile:
it’s out of scope for this doc, but you can take a look at: https://juju.is/docs/sdk/add-a-secret-to-a-charm
