A few weeks ago I deployed charm offline mongodb-k8s by cloning charm by charm folder dowloaded, mongodb started ok with OSM services on Ubuntu18.04 VM. After VM reboot some times, mongodb-k8s application is stuck with status waiting
, pod mongodb-k8s-0 status Init:0/1
. I have also tried remove-application then deploay again but I still get the error.
And i have a bit confuse why container k8s_juju-operator_mongodb-k8s-operator
not clean after I remove-application mongodb-k8s. I attached some logs below.
$ juju status
osm osm k8scloud 2.8.8 unsupported 02:50:14Z
App Version Status Scale Charm Store Rev OS Address Notes
mongodb-k8s mongo:latest waiting 1 mongodb-k8s local 6 kubernetes 10.100.111.219
mongodb-k8s/5* waiting idle 10.244.0.84 27017/TCP waiting for container
$ docker logs --tail 20 -f k8s_juju-pod-init_mongodb-k8s-0_osm_99959ace-d9b4-44d4-b21b-6a6fcdd40940_0
2021-03-05 01:49:26 INFO juju.cmd supercommand.go:54 running jujud [2.8.8 0 1d2677ae1d65f10bd15e9e29ab5e0f0cca70898a gc go1.14.10]
2021-03-05 01:49:26 DEBUG juju.cmd supercommand.go:55 args: []string{"/var/lib/juju/tools/jujud", "caas-unit-init", "--debug", "--wait"}
$ docker logs --tail 20 -f k8s_juju-operator_mongodb-k8s-operator-0_osm....
2021-03-05 02:51:04 INFO juju.worker.caasoperator.uniter.mongodb-k8s/5 uniter.go:302 unit "mongodb-k8s/5" started
2021-03-05 02:51:04 INFO juju.worker.caasoperator.uniter.mongodb-k8s/5 uniter.go:314 hooks are retried true
2021-03-05 02:51:15 ERROR juju.worker.caasoperator caasoperator.go:641 could not get pod "unit-mongodb-k8s-5" "mongodb-k8s-0" Get "https://10.96.0.1:443/api/v1/namespaces/osm/pods/mongodb-k8s-0": net/http: TLS handshake timeout
2021-03-05 02:51:15 INFO juju.worker.caasoperator.uniter.mongodb-k8s/5 uniter.go:286 unit "mongodb-k8s/5" shutting down: catacomb 0xc0009bc400 is dying
2021-03-05 02:51:15 INFO juju.worker.caasoperator.runner runner.go:558 stopped "mongodb-k8s/5", err: getting pod status for unit "unit-mongodb-k8s-5", container "mongodb-k8s-0": Get "https://10.96.0.1:443/api/v1/namespaces/osm/pods/mongodb-k8s-0": net/http: TLS handshake timeout
2021-03-05 02:51:15 ERROR juju.worker.caasoperator.runner runner.go:442 exited "mongodb-k8s/5": getting pod status for unit "unit-mongodb-k8s-5", container "mongodb-k8s-0": Get "https://10.96.0.1:443/api/v1/namespaces/osm/pods/mongodb-k8s-0": net/http: TLS handshake timeout
