I recently reissue the vault certificates after they expired and my cloud stooped working.
But now I am facing this problem that i don’t know how to solve. It seams nova has a problem
mchc@ubuntu:/data/git/openstack-cfg/client$ openstack server list --all-projects
Unexpected API Error. Please report this at http://bugs.launchpad.net/nova/ and attach the Nova API log if possible.
<class 'neutronclient.common.exceptions.ServiceUnavailable'> (HTTP 500) (Request-ID: req-6f1ca795-bf57-448b-8c5a-be404415a2c0)
The neutron log error is :
geoint@MAAS-01:~$ juju ssh neutron-api/0
Last login: Tue Mar 26 15:30:49 2024 from 10.2.101.2
ubuntu@juju-5025f7-3-lxd-3:~$ tail /var/log/neutron/neutron-server.log
2024-03-26 15:37:04.990 131414 ERROR neutron File "/usr/lib/python3/dist-packages/ovs/stream.py", line 811, in connect
2024-03-26 15:37:04.990 131414 ERROR neutron self.socket.do_handshake()
2024-03-26 15:37:04.990 131414 ERROR neutron File "/usr/lib/python3/dist-packages/OpenSSL/SSL.py", line 1828, in do_handshake
2024-03-26 15:37:04.990 131414 ERROR neutron self._raise_ssl_error(self._ssl, result)
2024-03-26 15:37:04.990 131414 ERROR neutron File "/usr/lib/python3/dist-packages/OpenSSL/SSL.py", line 1566, in _raise_ssl_error
2024-03-26 15:37:04.990 131414 ERROR neutron _raise_current_error()
2024-03-26 15:37:04.990 131414 ERROR neutron File "/usr/lib/python3/dist-packages/OpenSSL/_util.py", line 57, in exception_from_error_queue
2024-03-26 15:37:04.990 131414 ERROR neutron raise exception_type(errors)
2024-03-26 15:37:04.990 131414 ERROR neutron OpenSSL.SSL.Error: [('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')]
2024-03-26 15:31:39.896 126255 ERROR neutron OpenSSL.SSL.Error: [('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')]
al compute services are up:
mchc@ubuntu:/data/git/openstack-cfg/client$ openstack compute service list
| ID | Binary | Host | Zone | Status | State | Updated At |
| 4224d70a-f8af-4b09-b5d5-ccb45287761d | nova-scheduler | juju-5025f7-1-lxd-4 | internal | enabled | up | 2024-03-26T15:35:38.000000 |
| 5fdbb26b-7a2a-49e3-9cb1-e0ab9d50744d | nova-scheduler | juju-5025f7-2-lxd-4 | internal | enabled | up | 2024-03-26T15:35:37.000000 |
| 5f465bb4-edfc-4499-b69c-4d208d5e2aae | nova-conductor | juju-5025f7-2-lxd-4 | internal | enabled | up | 2024-03-26T15:35:42.000000 |
| 402b43ae-3ead-40b4-87af-c2bdc7392808 | nova-conductor | juju-5025f7-0-lxd-4 | internal | enabled | up | 2024-03-26T15:35:42.000000 |
| d351d86f-87e7-4a7b-a8d3-df1c616229bf | nova-scheduler | juju-5025f7-0-lxd-4 | internal | enabled | up | 2024-03-26T15:35:38.000000 |
| eaceda27-a46b-4b2e-911c-cf6c99dda28b | nova-conductor | juju-5025f7-1-lxd-4 | internal | enabled | up | 2024-03-26T15:35:34.000000 |
| 8ec65e3e-9f74-4936-8612-335a446b7292 | nova-compute | key-ox.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| 23241ad8-a77a-408e-b291-baf957cc3bea | nova-compute | stable-liger.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| ec2cebd4-65e3-4c4d-84d8-135022727c8d | nova-compute | star-koala.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| bc29c17b-ad85-4d09-b7a4-1493b0601c24 | nova-compute | liked-hermit.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| ce6c5a79-3174-4b47-b365-a63a7b473428 | nova-compute | exotic-goblin.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| 3d42d217-daa3-4582-aabc-d5b3f3b47c98 | nova-compute | clean-hog.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| 4e022854-1511-4928-bdd5-920826069c12 | nova-compute | calm-stag.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| 967ea90e-417c-4d1d-9e5a-f25128a45ef6 | nova-compute | pure-rabbit.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| 385901eb-5237-448a-9db9-17a89498e2cf | nova-compute | immune-mite.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| 4d63ec87-378f-4e85-8ca0-d1e2960d91db | nova-compute | vital-iguana.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| 2b68b268-433e-4174-b175-2a3662de8808 | nova-compute | loyal-glider.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
| 033ab76a-7436-422b-b0ea-9f044c563318 | nova-compute | sure-pony.maas | MID-PCTY | enabled | up | 2024-03-26T15:35:37.000000 |
