I follow all the instructions, but the juju bootstrap microk8s micro command inevitably returns this:
$ juju bootstrap microk8s micro
Creating Juju controller "micro" on microk8s/localhost
Fetching Juju Dashboard 0.3.0
Creating k8s resources for controller "controller-micro"
Starting controller pod
Bootstrap agent now started
Contacting Juju controller at 10.152.183.233 to verify accessibility...
ERROR unable to contact api server after 1 attempts: unable to connect to API: dial tcp 10.152.183.233:17070: connect: connection refused
Have completely wiped the install and tried again multiple times with the same results.
Looking at the mongodb log in /var/log/containers, it has these errors:
2020-11-17T13:59:04.624783383-08:00 stdout F 2020-11-17T21:59:04.624+0000 I CONTROL [main] Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'
2020-11-17T13:59:04.625982877-08:00 stdout F 2020-11-17T21:59:04.625+0000 E NETWORK [main] cannot read certificate file: /var/lib/juju/server.pem error:02001002:system library:fopen:No such file or directory
2020-11-17T13:59:04.626097973-08:00 stdout F 2020-11-17T21:59:04.626+0000 F CONTROL [main] Failed global initialization: InvalidSSLConfiguration: Can not set up PEM key file.
Not sure if it’s related or not?
Any ideas? This is an Ubuntu 20.10 desktop system.
I’m experiencing the same problem on Ubuntu 20.04, following the microk8s install instructions. Controller creation appears to go well until the “attempt to verify accessibility”:
14:26:04 DEBUG juju.kubernetes.provider bootstrap.go:884 Successfully assigned controller-mk8s-ctlr/controller-0 to twelf
14:26:04 DEBUG juju.kubernetes.provider bootstrap.go:884 Pulled images
14:26:04 DEBUG juju.kubernetes.provider events.go:52 getting the latest event for "involvedObject.name=controller-0,involvedObject.kind=Pod"
14:26:04 DEBUG juju.kubernetes.provider.watcher k8swatcher.go:115 fire notify watcher for controller-0
14:26:05 DEBUG juju.kubernetes.provider events.go:52 getting the latest event for "involvedObject.name=controller-0,involvedObject.kind=Pod"
14:26:05 DEBUG juju.kubernetes.provider.watcher k8swatcher.go:115 fire notify watcher for controller-0
14:26:05 DEBUG juju.kubernetes.provider bootstrap.go:884 Created container mongodb
14:26:05 DEBUG juju.kubernetes.provider bootstrap.go:884 Started mongodb container
14:26:07 DEBUG juju.kubernetes.provider.watcher k8swatcher.go:115 fire notify watcher for controller-0
14:26:07 DEBUG juju.kubernetes.provider events.go:52 getting the latest event for "involvedObject.name=controller-0,involvedObject.kind=Pod"
14:26:07 DEBUG juju.kubernetes.provider bootstrap.go:884 Created container api-server
14:26:07 DEBUG juju.kubernetes.provider bootstrap.go:884 Started controller container
14:26:07 INFO cmd bootstrap.go:972 Starting controller pod
14:26:07 INFO cmd bootstrap.go:669 Bootstrap agent now started
14:26:07 DEBUG juju.kubernetes.provider events.go:52 getting the latest event for "involvedObject.name=controller,involvedObject.kind=StatefulSet"
14:26:07 INFO juju.juju api.go:330 API endpoints changed from [] to [10.152.183.215:17070]
14:26:07 INFO cmd controller.go:93 Contacting Juju controller at 10.152.183.215 to verify accessibility...
14:26:07 INFO juju.juju api.go:78 connecting to API addresses: [10.152.183.215:17070]
14:27:07 INFO cmd controller.go:135 Still waiting for API to become available: starting proxy for api connection: waiting for pod controller-0 to become ready for tunnel: context deadline exceeded
14:27:07 INFO juju.juju api.go:78 connecting to API addresses: [10.152.183.215:17070]
14:28:07 INFO cmd controller.go:135 Still waiting for API to become available: starting proxy for api connection: waiting for pod controller-0 to become ready for tunnel: context deadline exceeded
14:28:07 INFO juju.juju api.go:78 connecting to API addresses: [10.152.183.215:17070]
14:29:07 INFO cmd controller.go:135 Still waiting for API to become available: starting proxy for api connection: waiting for pod controller-0 to become ready for tunnel: context deadline exceeded
14:29:07 INFO juju.juju api.go:78 connecting to API addresses: [10.152.183.215:17070]
14:30:07 INFO cmd controller.go:135 Still waiting for API to become available: starting proxy for api connection: waiting for pod controller-0 to become ready for tunnel: context deadline exceeded
14:30:07 INFO juju.juju api.go:78 connecting to API addresses: [10.152.183.215:17070]
14:31:07 INFO cmd controller.go:135 Still waiting for API to become available: starting proxy for api connection: waiting for pod controller-0 to become ready for tunnel: context deadline exceeded
14:31:07 INFO juju.juju api.go:78 connecting to API addresses: [10.152.183.215:17070]
14:32:07 INFO cmd controller.go:135 Still waiting for API to become available: starting proxy for api connection: waiting for pod controller-0 to become ready for tunnel: context deadline exceeded
14:32:07 INFO juju.juju api.go:78 connecting to API addresses: [10.152.183.215:17070]
<hit ^C at this point to cancel and cleanup>
Additional information: the log file from the failing pod0:
[twelf:juju () 263] => kc logs -n controller-mk8s-ctlr pod/controller-0 mongodb
2021-06-24T22:26:06.591+0000 I CONTROL [main] Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'
2021-06-24T22:26:06.593+0000 E NETWORK [main] cannot read certificate file: /var/lib/juju/server.pem error:02001002:system library:fopen:No such file or directory
2021-06-24T22:26:06.593+0000 F CONTROL [main] Failed global initialization: InvalidSSLConfiguration: Can not set up PEM key file.
Indeed, there is no such PEM file in the location being searched. Is this the right path? Should there me a PEM file there? If so, how is it created?
Is there any solution as I am also facing the same issue.
18:08:47 INFO cmd controller.go:135 Still waiting for API to become available: starting proxy for api connection: waiting for pod controller-0 to become ready for tunnel: context deadline exceeded
ERROR contacting controller (cancelled): starting proxy for api connection: waiting for pod controller-0 to become ready for tunnel: context deadline exceeded
So it looks like we only wait for 1 minute for the pod to be ready. I think this is a bit short, I’ll make a PR to improve the time out for this. This will hopefully land in next week’s release.
Is there a chance that you are running on btrfs? It may be worth enabling --feature-gates="LocalStorageCapacityIsolation=false" in the kubelet config (check the microk8s logs to see whether kubelet cannot establish the storage path)
