Enterprise Store Documentation
The enterprise-store operator installs and manages the
enterprise-store snap with Juju. Compared to running the bare snap, the charm adds the
ability to run several nodes for high availability and to drive all
configuration declaratively through Juju.
Deployment modes
The enterprise-store lets you run the Snap Store on your own premises, either as
a proxy in front of the global Snap Store or as a fully self-contained store for
airgapped environments.
Proxy mode
The default mode. The enterprise-store acts as an edge proxy in front of the
global Snap Store. Devices are pointed at the proxy and all traffic to the Store
flows through it, which lets you cache snaps and override the revisions your
devices receive. The unit needs to be able to reach the Snap Store to install
the snap and to proxy requests. See the Proxy mode deploy guide.
Offline / airgapped mode
Nothing reaches the internet. The snaps that make up the enterprise-store are
shipped in through the store-bundle resource, and blob storage is provided by
an S3 backend via the s3-integrator charm.
Snaps and brand stores are exported elsewhere and pushed into the store. See the
Offline mode deploy guide.
High availability
Either mode can be run with multiple units behind the
haproxy charm, which terminates client TLS at the
edge and load-balances across the units. See the
High availability deploy guide.
Navigation
Navigation
| Level | Path | Navlink |
| 1 | overview | Overview |
| 1 | deploy | Deploy |
| 2 | deploy-proxy | Proxy mode |
| 2 | deploy-offline | Offline mode |
| 2 | deploy-ha | High availability |
| 1 | upgrading | Upgrading |
| 1 | contributing | Contributing |
Redirects
Mapping table
| Path | Location |
